"honk" or the Toyota "beep" when locking/unlocking doors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheOtherGuy, Jul 27, 2010.
  1. Jul 27, 2010 at 12:43 PM
    TheOtherGuy
    TheOtherGuy [OP] Well-Known Member
    Cajun Country
    05 Access 4x4
    I bought my truck used and I think the previous owner put some type of system on it that makes the horn honk twice when unlocking and once while locking. This horn honk is too loud and I sometimes feel bad when doing it right next to my elderly neighbors window.
    I noticed that most Toyota including my old Lexus have a signature Toyota beep that is still audible but not too loud. Does anyone know how I can change it to the "Toyota beep"
    2005 SR5
  2. Jul 27, 2010 at 12:46 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Two days into it I removed the "beeper" from my '10 .... I can take the flashers but that damn chirp is gone.
  3. Jul 27, 2010 at 12:47 PM
    mr2crazed
    mr2crazed Well-Known Member
    Paso Robles, CA.
    06 DC PreRunner SR5
    Yeah, I'm happy my '06 doesn't.
  4. Jul 27, 2010 at 1:00 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    I would also be fine with only having the flashers. The main issue is that the Honk is just way too loud.
  5. Jul 27, 2010 at 1:38 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
  6. Jul 27, 2010 at 1:40 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My 07 just flashes the lights. The only thing I find annoying is having to press the unlock button twice to unlock all the doors. I wish it would unlock all of them on one press.
  7. Jul 27, 2010 at 5:45 PM
    TheOtherGuy
    Cajun Country
    05 Access 4x4
    Ok, I figured this out. It took a bit of playing a digging but I finally got it. I found out my truck has the KARR alarm system(I think it was a factory option) in it and has a blue LED light below the steering wheel. On the back of the light there is a button.
    To turn the "honks" on and off all you need to do is turn the key to "on" then remove the key, then press the button on the back of the LED 6 times. The horn will sound to let you know its worked.
    Now I only have the flashers when I lock and unlock.
    crackils likes this.
  8. Jul 27, 2010 at 5:48 PM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
  9. Oct 3, 2014 at 9:57 PM
    edgarcalifornia
    edgarcalifornia New Member
    Ed
    California
    09 Tacoma
    Many many thanks. This helped me to get rid of that stupid honk.
    Now I only have the beeps and the flashers when I lock/unlock the doors but I am a happy camper this way.
    Thanks again
  10. Oct 3, 2014 at 10:59 PM
    Ray
    Ray Well-Known Member
    San Diego
    09 Pre-Runner
    I've got an '09 and would rather have the "honk" then the "beep." Is there a way to change that?
    Thanks,
    Ray
  11. Oct 3, 2014 at 11:08 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I want the horn instead of the beep. Everyone wants the other way around. Is it even possible to get a horn to sound?
