Hood alignment help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NomadicCypress, Sep 27, 2021.
  1. Sep 28, 2021 at 8:18 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    All I did was loosen the bolts. Its easy if you get someone to help you with it
  2. Jun 14, 2023 at 9:50 AM
    Yotamachine
    Yotamachine Well-Known Member
    2001 Yota
    Reviving.
    I am having trouble following the diagram with the different hood areas. For example, in the first illustration, where are areas "A" and "B"? Similarly, where are areas "C" and "D"? I take area "D" to be the gap between fender and hood but not sure. Area "C" ... is the illustration, at least for me, is hard to follow. Appreciate anyone that can help with better understanding the illustrations by pointing out which parts I should be looking at my newly acquired hood.
  3. Dec 2, 2023 at 2:09 PM
    Mech_Eng
    Mech_Eng Well-Known Member
    Birmingham, AL
    2009 TRD 4x4 DCSB
    See Build Page
    Can someone identify the source of this image? I tried google lens. Is it from one of the four volumes of the factory repair manual, or is there a separate body repair manual that includes this image?
  4. Dec 5, 2023 at 2:00 PM
    Jeg23423
    Jeg23423 New Member
    Joseph
    MGM 2023 Tacoma SR5 4x4
    Did u ever get this sorted out? Im in the same boat after an oem hood swap accept my tolerances are radically shifted to the passenger side to the point of rubbing where the hinge seems to be the point where the misalignment seems to originate. Any advice would be appreciated!
  5. Dec 6, 2023 at 9:32 AM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    The hood bolts have a shoulder and center themselves in the hinge holes. The shoulder is basically the same size as the holes in the hinge which results in NO adjustment available. I ran into this while swapping hoods for a scooped version. I imagine one could bend the hinges as necessary to align but I decided to use a standard bolt and flat washer in place of the shoulder bolts. This allowed a small amount of hood adjustment.
    Jeg23423 likes this.
  6. Dec 6, 2023 at 10:07 AM
    Jeg23423
    Jeg23423 New Member
    Joseph
    Do the dealerships sell the bolts needed or did you have to grab some at Home Depot?
  7. Dec 6, 2023 at 10:14 AM
    kaljam
    Bill
    New Hampshire
    I imagine the dealerships would have the factory bolts with the shoulders. For standard bolts/washers I would go to HD or a real hardware store (HD hardware sucks).
  8. Dec 6, 2023 at 2:32 PM
    Jeg23423
    Jeg23423 New Member
    Joseph
    Ok Forsure yeah I was thinking of just tapping the hinge a bit but with my luck I’ll jack something else up ha but if you happen to know what size bolt you ended up using. I’ve seen on a few forums saying it’s a 8x1.25 thread I’m just not sure what length with the washer and such. Also appreciate the insight I couldn’t find anything on this to save my life ha
  9. Dec 6, 2023 at 3:50 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Use non-shouldered bolts but only one on each side…..it’ll get you some side to side, or just adjust the fenders.
  10. Dec 6, 2023 at 3:57 PM
    kaljam
    Bill
    New Hampshire
    Its not gonna move with a shouldered bolt in there! Not sure the logic with one per side but whateva.
  11. Dec 6, 2023 at 4:18 PM
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    Unless you look for a specific grade and possibly brand all real stores are just as likely to have the same quality level default choices of in stock hardware whether you go with hd, lowe’s, true value, ace, etc. even grainger/zoro.
  12. Dec 6, 2023 at 4:30 PM
    kaljam
    Bill
    New Hampshire
    Ya - what he said - I guess I have no clue what I'm talking about. Go to Home Depot!
  13. Jun 23, 2024 at 5:02 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Reviving this thread....did you ever get this problem solved?
  14. Jun 23, 2024 at 6:12 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    You might have better luck getting a response if you tagged @NomadicCypress. This way he knows to look.
  15. Jun 23, 2024 at 11:28 PM
    #35
    NomadicCypress
    NomadicCypress [OP] Well-Known Member
    2023 Solar Octane TRD Pro M/T
    I did not, I tried different bolts and everything. I think it just had to do with slightly different tolerances on the new hood and the truck.
    I guess I did solve it in that I traded the truck lol
