Hood and tachometer problems (Dealership response)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rdizzle, May 18, 2017.
  1. May 18, 2017 at 5:16 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Hey yall,
    This is my first time posting on this site. I just bought a new 2017 last month and have had several problems, some of which are being repaired by the dealership and I'd like to share the dealership response/resolution in case any of yall have similar problems.
    Problems:
    1) Hood vibrates at speeds over 30-35 mph.
    2) Tachometer intermittently doesn't move smoothly. It "ticks" like the second hand of a clock.
    Brought it to dealership:
    I told the dealership that based on my research, many 2017 tacomas have issues with the hood vibrating and that it seems as if its an issue with the adhesives under the hood.
    Based on my research on this site, some people with similar tach problems didn't receive any help from dealership because the problem was intermittent and the dealer was unable to replicate the problem. I took videos of the problem in case they couldn't replicate the problem. Luckily, as I was pulling into the dealership, the tachometer was acting up so I was able to show them immediately.
    Dealership response:
    After being at the dealer for about 2 hours, they told me that the hood problem was caused by adhesive issues. They said their body shop will be able to fix the problem.
    As far as the tachometer, they verified the problem but did not have a resolution. They said they needed to "call their engineers in California to figure out what to do." The dealer estimated it will take about a week to repair the issues and gave me a loaner.
    I will update this post when I have more information
  2. May 18, 2017 at 5:25 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Welcome to TW, mang.
    Kilokato and GPsevinSixx like this.
  3. May 18, 2017 at 6:04 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Tell the dealership there is a tsb for the tachometer issue. I have seen the tsb.
    GPsevinSixx likes this.
  4. May 18, 2017 at 6:06 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    New car dealers service departments suck. If you go in knowing they cant diagnose any issue and can only do what others have solved you will have a better experience. The tach issue for example. It would take about 3 minutes to plug in a scan tool to tell if the issue was coming from ecm or in cluster.
    Welcome to tw and the frustrating life that is toyota dealer service.
  5. May 18, 2017 at 6:08 AM
    Modesto Tacoma
    central california
    LIMITED 4X4
    Tell the dealership there is a tsb for the tachometer issue. Here is the tsb number t-sb-0148-16
  6. May 18, 2017 at 6:08 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Do you happen to know the tsb number or where I can find it? I have tried looking but had no luck
  7. May 18, 2017 at 6:13 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    I just looked that up but it is for 2016 trip meter resetting. Doesn't show anything about 2017 tachometer problems
  8. May 18, 2017 at 6:25 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Several guys on here have had the Cluster replaced from issues like yours.
    2016Tacoman likes this.
  9. May 18, 2017 at 6:28 AM
    Modesto Tacoma
    central california
    LIMITED 4X4
    It's probably the same as the 16.
  10. May 18, 2017 at 6:49 AM
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    sub'd..it's only happened once so far, about 2-3 months ago, but i noticed the my speedometer didnt move smoothly.
  11. May 18, 2017 at 7:02 AM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Smitty had his Tach replaced
    Caligula and shakerhood like this.
  12. May 18, 2017 at 7:10 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    I want my hood replaced....PLEASE TOYOTA
    The hammer likes this.
  13. May 18, 2017 at 7:20 AM
    Chazmann
    Chazmann A/C TRD Sport V6 4x4 6-MT
    Did you A/T or 6-MT?
  14. May 18, 2017 at 7:27 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Welcome rdizzle!
    I don't understand how they don't have have a resolution for the tach, If it's verified as not working as it should it ought to be replaced end of story.
    But what suspect as to what's really going on is that they're waiting for the Toyota field engineer to approve the replacement.
    As some members have had issues with tach also, please do keep us updated.
    It's coming in the mid model facial uplift before the 4th gen comes out in another ten yrs.
    shakerhood and 2016_dbag[QUOTED] like this.
  15. May 18, 2017 at 8:16 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Auto. I used to have a MT wrangler as my daily driver and it got real old, real quick lol
  16. May 18, 2017 at 8:17 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Thank you! Why do you think it is suspect? What could it mean that they are waiting for approval?
    And yes, I will keep yall posted
  17. May 22, 2017 at 3:58 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Update:
    After waiting three days without hearing anything from the dealership, I decided to call for an updated. As expected, the hood vibrations were caused by the adhesives losing contact under the hood.
    As far as the tachometer problem, also as expected, they said that they needed to put in a new cluster and that it would still be another 3-4 days until the vehicle is ready. I'll keep you guys updated once I pick up my truck and let you know how everything is
  18. May 22, 2017 at 6:49 AM
    The hammer
    It means the Toyota field tech will ask and or direct the stealer tech into troubleshooting to find the fault, and the Toyota field will make the final approval on repair, not the dealer tech.
    TheCookieMonster likes this.
  19. May 25, 2017 at 5:27 AM
    rdizzle
    rdizzle [OP] Member
    NC
    2017 Black Tacoma
    Update:
    Dealership says cluster is on backorder. Truck won't be ready for at least 2 more weeks but it will probably be much longer than that.
  20. May 25, 2017 at 5:43 AM
    The hammer
    WTG OP, you grabbed the bull by its horn and got it to yield
    Cheers!
    BillsSR5 and TheCookieMonster like this.
