Hood Antenna Mount, now available.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by monkeyevil, Jan 29, 2019.
  1. Feb 4, 2019 at 8:18 AM
    monkeyevil
    monkeyevil [OP] Victory 4x4
    Daryl
    Kalamazoo, MI
    It's set-up for 3/8" NMO mounts, but they have to be able to handle .190 thickness. The Liard part number I linked includes a bushing to work with either 3/8 or 3/4, the PCTEL is 3/8 only. Either should be good to go. The antenna I linked would be great for that radio.
    It's pretty damn solid, I would say comparable to a thick mirror mount if you have any experience with those. Haven't done any long term testing on an antenna that big though.
    Scrat and Mtn Mike[QUOTED] like this.
  2. Feb 4, 2019 at 10:05 AM
    ETsemaj
    ETsemaj @Koditten Pirate Radio member #001
    James
    Cape Canveral, FL
    2018 Cement Tacoma Off Road
    speaker and tweater upgrade DMM phone mount and a large wishlist
    awesome, thats the PCTEL im trying to get off Amazon.
    victory4x4 likes this.
  3. Feb 4, 2019 at 7:57 PM
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    subbed
  4. Feb 4, 2019 at 8:01 PM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    I have that same radio, how do you have the head mounted up above the mirror like that?
  5. Feb 4, 2019 at 9:19 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    How well do the antennas clear the windshield and roof edge while the hood is up? Can someone post a side view showing it with their hood fully open?
  6. Feb 4, 2019 at 9:28 PM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
    The only reason I'm shying away from this mount is the possible exposure risks. Any one else have thoughts on this?
  7. Feb 4, 2019 at 9:32 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It depends on antenna design and transmit power. With my setup exposure exceeds recommended levels at 15 watts on 2m and 10 watts on 70cm with a hood mount.
  8. Feb 4, 2019 at 9:38 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Cool!
  9. Feb 4, 2019 at 9:39 PM
    Boomer3731
    2017 DCSB TRD Sport
    Yeah, it's looking like 2.15dBi gain and 50W at 70cm is no bueno for this location.
  10. Feb 4, 2019 at 10:42 PM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    Dang I wish you had posted this a few weeks sooner. I’m using a relentless fab ditch light mount. But this is a much cleaner option.
  11. Feb 4, 2019 at 11:04 PM
    OnHartung'sRoad
    Do you have a cellphone? o_O
  12. Feb 4, 2019 at 11:42 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Some quick research shows that most cellphones transmit at below 2 watts and typically less than 1 watt.
  13. Feb 5, 2019 at 7:32 AM
    monkeyevil
    Daryl
    Kalamazoo, MI
    Dang on that low power, how much gain?
    Yeah depending on cable losses 50w can put you over.
  14. Feb 5, 2019 at 7:41 AM
    monkeyevil
    Daryl
    Kalamazoo, MI
    Exposure risks will depend on antenna design and power. Also, one has to remember that exposure risks were calculated for stations with a much higher duty cycle than we see in a mobile rig, and the FCC recommendations reflect that. Because of that, I am comfortable with my setup (50w max, 2.5Dbd gain antenna) as I don't transmit much at full power, and even if I need to it's not often.
  15. Feb 5, 2019 at 8:08 AM
    #35
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    3.5dbi on 2m, 6.0dbi on 70cm.
    Like you said though, all personal preference for how much you care about exposure and highly dependent on usage and duty cycle.
  16. Feb 5, 2019 at 8:09 AM
    #36
    OnHartung'sRoad
    Yeah, but I don’t hold my whip next to my head when I transmit. Just pointing out that its a lot closer than the antenna and higher frequencies do have more bio affects.
  17. Mar 15, 2019 at 7:28 PM
    #37
    ETsemaj
    James
    Cape Canveral, FL
    So just installed my set up today (d710g with the same antenna you used). But ive got 20w forward and 10w reflected. So comes out to 6:1. Im sure its something i did. I was not able to get the white plastic piece to fit on the connector though when i installed it on the plate. Would that be the issue? I check resistance on the cable on its all good.
  18. Mar 15, 2019 at 9:28 PM
    #38
    Mattchew
    Mattchew Well-Known Member
    Coquitlam, BC, Canada
    2017 tacoma TRD sport
    Toytec boss lift Ultralight racing adjustable UPC K&N cold air intake Magnaflow Catback exhaust All LED lights Oemassive headlights with HID LED pods in rigid fog light mounts 50" curved windshield LED Caliraised side shooter ditch mount LED Behind grill 30" LED SSO slimline bumper with LED bar and smittybilt x20 synthetic winch TED PRO taillights with diode dynamics brake as turn controller LED bed lights LED running board lights LED under hood light Line-x trifold hard tonneau cover Switchpros system Yaesu vhf radio
    @monkeyevil will this work with either Rago or caliraised ditch light brackets?
  19. Mar 15, 2019 at 10:27 PM
    #39
    monkeyevil
    Daryl
    Kalamazoo, MI
    I think that white plastic isolator not being installed is an issue. Also check resistance between your mount and a ground lug on the fender or battery. You may just need a better ground :thumbsup:
  20. Mar 15, 2019 at 10:28 PM
    #40
    monkeyevil
    Daryl
    Kalamazoo, MI
    Probably not since they occupy the same place.
