Hood insulation
Discussion in '4th Gen. Tacomas (2024+)' started by MarkusJ, Apr 21, 2024.
  1. Nov 30, 2024 at 12:09 PM
    #41
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Mine came with the hood sound deadening. I'm quite sure the engineers have the cooling system figured out with the 3" water pipes.
    PDKTaco likes this.
  2. Nov 30, 2024 at 7:20 PM
    #42
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    At least that stuff doesn't make your car look like the damn Apollo lunar module. But the cheap version appears to make young kids happy when you burn it. So that's a positive.
    https://www.amazon.com/Auto-Sound-Dampening-Material-Mat/dp/B09MLT72F6
    idahodesert likes this.
  3. Apr 6, 2025 at 3:32 PM
    #43
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    No.
    Can a person hear a loud vehicle outside in the street, through a glass window while sitting inside their home? Yes.
    So, the driver of a vehicle can hear the noise of an engine in front of them through a single sheet of metal and a windshield.
  4. Apr 6, 2025 at 7:27 PM
    #44
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    The insulation will help the paint on the hood to not prematurely fail
  5. Apr 7, 2025 at 6:24 AM
    #45
    Iqudayo
    Iqudayo Well-Known Member
    Antonio
    Toyota Tacoma
  6. Apr 13, 2025 at 10:17 AM
    #46
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    Only concern I have with this is whether or not it'll handle the heat of the engine - and I don't want to risk finding out the hard way.
    I grew up with iron block V8's and straight sixes. Ticks, rattles and knocks that were audible, were signs of engine issues - and that thought is ingrained in me still, even though I know direct injection pumps and other newer technologies (to include using aluminum as an engine block) create more noise.
    Still, this is a noisy engine, and I instinctively feel it's a problem. My truck was slightly out of alignment (steering slightly off center), which the dealer took care of. I asked about the noise, and the master tech jumped in and we went for a ride. His answer was "yeah, they're noisy. The Corollas are like this too, but I can call a factory rep if you want..."
    I've been all over the engine with a mechanic's stethoscope, identifying each component's various sound(s); but there's still that slight clackety-sound under load around 3-4k rpms. Drives me nuts, and I think the hood insulation (which I don't have) would help.
    I did run across this video, and haven't seen it posted. I had been thinking about doing something similar.
  7. Apr 13, 2025 at 11:28 AM
    #47
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    If it was an issue, the higher trims would not come with it installed.
    OregontoBajaCA likes this.
  8. Apr 13, 2025 at 12:54 PM
    #48
    dneal
    MidMO
    24 TRD OR 6M
    See that Amazon link I quoted?
    Reading may be fundamental, but context is crucial.
    CrispyTacoLover likes this.
  9. Jul 3, 2025 at 10:38 AM
    #49
    NoSlushbox4Me
    NoSlushbox4Me Member
    Texas
    2025 TRD Sport 6MT
    Any thoughts on the 53341-AK010 hood insulation pad fitting a 2025 TRD Sport? Same as 2024 truck just +1 year?
    <Edit> Scratch that. I did the unthinkable and lifted my hood. My truck already has the OEM pad.
    PDKTaco likes this.
