HOOD INSULATOR/SOUND DEADENER
Discussion in '4th Gen. Tacomas (2024+)' started by tacoscott24, Aug 24, 2024.
  1. Jan 2, 2025 at 9:15 AM
    tacoscott24
    tacoscott24 [OP] Active Member
    24 SR5 DBLCAB
    Do you hear the loud rattle tapping sound upon accelerating or did the kilmat take care of it. I installed the insulator from Toyota but I still hear it. It might be a little quieter
  2. Jan 2, 2025 at 11:24 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    I've never heard a loud rattle like some describe but I did hear the injectors just a touch. That has certainly been reduced.
  3. Jan 2, 2025 at 11:29 AM
    cvillechopper
    Charlottesville, VA
    Very carefully ;) seriously, it was a bitch. You have to remove all of the upper trim on the A, B, and C pillars which means removing the lower trim on B and C. You also have to remove the rear light, front roof console, sun visors, rear coat hangers and the grab handle on the passenger side. The grab handle was the most difficult but all probably require some experience with interior trim. If you ha e the sunroof, there is also heavy duty velcro all around the opening.
    With all of this, you still can fully remove the headliner because of some wiring going to the front mirror/camera housing. I just let it hang gently and worked around it.
  4. Jan 2, 2025 at 4:33 PM
    Wahhabm
    Wahhabm Well-Known Member
    Monther
    I amngoing to do the doors and see. I highly doubt it am willing to tear the headliner that much. I had to pull the rear part to remove the 3rd light because I was routing an after market rear camera for the rearview camera that I installed and it was hard enough.
  5. Apr 4, 2025 at 9:22 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Has anyone added the OEM hood insulator panel to a manual transmission 4G? How did it go? I wouldn't mind quieting some of the clattering of the engine, but I would be sad if the turbo spooling noises were diminished!
  6. Apr 4, 2025 at 10:10 PM
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    Should work fine, the hoods are not different underneath. My manual transmission has it because its a premium package
  7. Apr 6, 2025 at 12:36 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I purchased a Carista OBD tool. You’ll have to pay at least a one month subscription to make the changes. I turned off piped in engine noise, blinkers go five times instead of three when you 1/2 pull the stalk, all seatbelt chimes off, and all windows down and sunroof open if you long hold the key fab.
    The dealer can make those changes too but I bet they won’t turn off the seatbelt chime. I figured what the hourly rate at a shop was more than the OBD tool.
