Hood Latch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Sep 7, 2023.
  1. Sep 7, 2023 at 12:07 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Pulled the Hood Latch under the dashboard and handle just flopped - hood didn't open - used vise grips on wire attached to the handle under the dash and it opened the hood - positioned the wire into the notch on the latch - ok now - don't know how it got out of the notch - thought it might help someone - first time I had this problem and it's a 2008.
  2. Sep 8, 2023 at 7:28 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Don't know if this might help, but the two rubber bumpers in the front edge of the hood can be turned out to increase pressure of the hood when closed allowing the hood to pop up more strongly when you pull the hood release lever. Worked like a charm for me when the hood wasn't popping open enough when I pulled the latch in the cab.
    FastEddy59 likes this.
  3. Sep 9, 2023 at 6:43 AM
    george3
    New Jersey
    Thanks for the reply - I'll check it out.
  4. Sep 9, 2023 at 6:46 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    That’s what it was on mine too.
