hood lift assist
Discussion in 'Technical Chat' started by El TacoBender, Jun 19, 2013.
  1. Jun 19, 2013 at 1:36 PM
    El TacoBender
    El TacoBender [OP] Well-Known Member
    Manuel
    always moving
    '03 taco sr5,4x4,v6
    -K&N CAI
    anyone have a first gen taco 02-04 that they added gas shocks to the hood to get rid of the hood support rod?
  2. Jun 20, 2013 at 5:52 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I have the Redline Quick Lift Plus:
  3. Jun 20, 2013 at 6:03 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    X2 on redline tuning's products here
    I can't remember which I have bc I was a tester back in the day
  4. Jun 20, 2013 at 6:10 AM
    BigOly
    BigOly Well-Known Member
    Bay Area, NorCal
    14 MGM DCSB TRD/OR 4x4
    OP, I'm in the market for a set too! :)
    Those that have already installed the redline, have you had any issues with bending of the hood hinges or any dampening issues?
    Over at trdparts4u they advertise their -Warrior Products HL71306 HoodLift By Warrior Products Hoodlift- as being "better then the rest", is this just BS marketing to sell more of their product?
    Here's how they advertise their hood lift product:
    "Others use different mounting points requiring excessively high pressure springs that can bend your hood hinges. Avoid other vendor’s claims that they have an “exclusive dampened gas spring”: all gas springs have oil in them that dampens the end of the stroke while lubricating the shaft seal. Hoodlift gas springs are specially made to our specifications and have that smooth, dampened opening you want when you open your hood or tail gate."
  5. Jun 20, 2013 at 6:26 AM
    JimBeam
    JB
    2015 Tundra
    Redline is top notch...I've had mine for as many years as they've been avail for the Tacoma and I've had ZERO issues...easy install and still work to this day
  6. Jun 20, 2013 at 9:52 AM
    El TacoBender
    Manuel
    always moving
    '03 taco sr5,4x4,v6
    -K&N CAI
    i need the specs of that redline kit if you have it man. everything for full/compressed/stroke lengths and force needed to close in pounds. rod diameter and the ball joint fitting size. lol i know its alot but im sure it came in the package they sent you. i work in a shop figured i could just grab to shocks and rivot in the bases and call it free :) thanks!!
  7. Jun 20, 2013 at 9:53 AM
    JimBeam
    JB
    2015 Tundra
    I've had them for several years...packaging is LONG gone
  8. Jun 20, 2013 at 10:16 AM
    El TacoBender
    Manuel
    always moving
    '03 taco sr5,4x4,v6
    -K&N CAI
    1.)can you check the overall length?
    2.)any idea how much the hood weighs,about 30ish lbs??
    ill figure out the exact mounting points
