Hood Lighting Kits - 1st & 2nd Gen - Ongoing group buy
Discussion in 'Anti-Dark' started by BeeRadd, Feb 27, 2014.
Poll closed Mar 30, 2014.
  1. .
    27 vote(s)
    21.3%
  2. .
    100 vote(s)
    78.7%
  1. Sep 16, 2014 at 2:38 AM
    #941
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    I cant wait to get my kit. Im only 6th down on the list. Its dark earlier now and had to give a few jump starts to people. This would def make it easier to see and look bad ass
  2. Sep 16, 2014 at 2:55 AM
    #942
    DrFunker
    DrFunker Well-Known Member
    ^^ It is pretty bad ass.
    :headbang:
    You will be happy with it, for sure.
  3. Sep 16, 2014 at 3:02 AM
    #943
    BeeRadd
    BeeRadd [OP] Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Not sure if the above list is the correct version of this list but im grabbing the next names off of it and sending PM's right now. Time to check those boxes fellas :)
    PMed:
    texastaco11
    V5ioV - PRO Kit
    angeldavid216 - PRO KIT
    Darryle - Pro Kit
    Drop4205 - Pro Kit CW
    Taco89 - Pro Kit
    AWF ROWD PRO KIT
    VonElling Pro Kit CW
    JTyfz450- Pro Kit CW
    tylertnt Pro kIt
    21iamsammy- PRO KIT CW
    kemosabee - Pro Kit CW
    NEXT:
    Mackattack - Basic kit (delayed waiting for parts to arrive)
    Glueman - Pro kit CW
    T@co_Pr3runn3r - Basic Kit CW
    rtrudel35 - Pro Kit CW
    AsianAnts - Pro Kit CW
    poolstick - Basic CW
    Ragamorph- Pro Kit CW
    str808taco - Pro Kit CW
    Emelianenkov- Pro Kit Regular White
    rkarabao CW Pro Kit
    Surfermatt- Basic Kit WW
    Aromeo620 - Pro
    nicapride305 basic kit
    surfsupl - Pro Kit CW
    rollacoasta15- Pro Kit CW
    Thefang - Pro Kit CW
    Jxepolis - Pro Kit CW
    PinnaclePete - Pro Kit WW
    WalkMan71-Pro Kit CW
    ThomasMore66-Pro Kit CW
    twotwentyswift=Pro Kit CW
  4. Sep 16, 2014 at 3:42 AM
    #944
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Woke up to my pm woot woot
  5. Sep 16, 2014 at 5:01 AM
    #945
    ThomasMore66
    Dallas/Fort Worth & Durango
    I cringe every time I see your sig pic.
  6. Sep 16, 2014 at 7:04 AM
    #946
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    That was the 1st time wheeling it... lol....
  7. Sep 16, 2014 at 8:32 AM
    #947
    jcmiller
    jcmiller New Member
    Tigard, OR
    2008 4Runner Sport Edition 4x4
    Metal Tech Front Bumper, Rigid Industries Dually D2's, ICON Stage 3, Total Chaos UCA's, Metal Tech upper and lower rear links, Metal Tech Sliders, Baja Rack, National Luna Dual Battery System, two Die Hard Platinum Batts, ARB 50qt Fridge, Front Runner Wheel Well Water tank and 12v pump, GOBI rear ladder, Rear Diff breather mod, fog light mod, LED body light swap
    Got my kit yesterday, install was easy. Thanks for the nice workmanship!
  8. Sep 16, 2014 at 12:46 PM
    #948
    JTyfz450
    JTyfz450 Well-Known Member
    Jeryck
    SoCal
    2012 TRD Sport DCSB MGM
    Got my PM early this morning :D. Finally gonna get the kit.
  9. Sep 16, 2014 at 1:27 PM
    #949
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I got the pm but never got the invoice
  10. Sep 16, 2014 at 7:35 PM
    #950
    james Daniel
    james Daniel Well-Known Member
    james
    13 TRD off road
    Got it today, really we'll put together and super bright. Thanks dude
  11. Sep 16, 2014 at 7:48 PM
    #951
    Tonkaman
    Tonkaman Well-Known Member
    Adding my name to the list!
    PMed:
    texastaco11
    V5ioV - PRO Kit
    Darryle - Pro Kit
    Taco89 - Pro Kit
    AWF ROWD PRO KIT
    tylertnt Pro kIt
    NEXT:
    rkarabao CW Pro Kit
    Aromeo620 - Pro
    Tonkaman- pro kit
  12. Sep 16, 2014 at 8:46 PM
    #952
    jxepolis
    jxepolis Well-Known Member
    Jared
    Lomita, CA
    2013 MGM Tacoma
    Are the 2 on the left CW or no? Need to update/change my order if they are not CW.
  13. Sep 17, 2014 at 3:44 AM
    #953
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Thanks for bailing on me last minute...lmao
    Good times...
  14. Sep 17, 2014 at 4:56 AM
    #954
    ThomasMore66
    Is there a followup pic? Was there a visit to the body shop? I'm guessing that you guys didn't start in that position with the passenger side in the gap.
  15. Sep 17, 2014 at 10:47 AM
    #955
    Lpfan420
    Lpfan420 Well-Known Member
    06 base 4x2
    Received my kit yesterday and will be installing soon as I wash my truck.
    Edit: just installed pro kit. Easy as can be. Thank you brad for a quality product.
  16. Sep 17, 2014 at 4:05 PM
    #956
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    Mine just shipped!!
  17. Sep 17, 2014 at 4:46 PM
    #957
    JTyfz450
    Jeryck
    SoCal
    Mine too :D
  18. Sep 17, 2014 at 5:43 PM
    #958
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Shit Im almost out! I've got like 6 CW Kits left :eek:
    I still have about 6 or 7 WW Kits left, im going to check the list but after I get rid of these CW I'll be trying to get rid of the WW.
    After the last CW Kit it will be (im guessing) about 3-8 weeks until the next batch is ready. Sorry guys :/ School is killing me right now and I am forced to slow production down on this thing.
  19. Sep 17, 2014 at 5:43 PM
    #959
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    8 Kits shipped out today. If you got the email with the tracking, it's comin'!
  20. Sep 17, 2014 at 6:45 PM
    #960
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Got it and installed. The LED strip was longer than the underside and curved around some, but I got it in.
