Hood not flush with fenders
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainAwesome, Dec 12, 2017.
  1. Dec 12, 2017 at 6:49 AM
    CaptainAwesome
    CaptainAwesome [OP] Well-Known Member
    Calgary, Alberta
    Noticed that my hood sits just a little lower than my fenders for the first time with my taco last night. Now that I noticed it, it drives me crazy.
    Is this common?
  2. Dec 12, 2017 at 6:50 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :bananadead:Trucks totalled time to trade for a 2018
    Adjust the rubber bumpers under the hood
    Jh8473, RedBeard1, JimboAnz and 8 others like this.
  3. Dec 12, 2017 at 6:53 AM
    CaptainAwesome
    Calgary, Alberta
    The entire hood is lower, even near the windshield. Would that help?
  4. Dec 12, 2017 at 6:54 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    worth a shot before you trade up
  5. Dec 12, 2017 at 6:58 AM
    CaptainAwesome
    Calgary, Alberta
    Lol I'm not getting rid of it. Just curious if this is common or if I messed something up doing something up or if this can be adjusted.
    If it's common, oh well I go on about my life. If it can be adjusted, okay great. I get it adjusted.
  6. Dec 12, 2017 at 7:02 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Pics??
  7. Dec 12, 2017 at 7:12 AM
    CaptainAwesome
    Calgary, Alberta
    I'm about to go in work so really don't have time for pics. It's just 1-2mm lower than the top of the fender hardly noticeable unless youre looking for it
  8. Dec 12, 2017 at 7:18 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    I have the same thing with my hood. I did a quick adjustment to the front by spinning the little bumpers up a turn or so till it was good. I have not yet taken the time to look at adjusting the back at all. I did not notice any of the bumper pads near the back. I have had to adjust the hood on other vehicles but I cannot say I have ever tried or needed to on a Toyota. I can not even be sure they can be adjusted, as I have not looked or tried.
    If the hinges can be adjusted, as many other vehicles can be, it will take several steps:
    • Measuring the height gap while closed (may be different on each side)
    • Mark current hing position on truck
    • Mark new desired position based on measurement
    • Loosen hinge
    • Raise hinge to the new position
    • Secure hinge
    • Repeat for other side
    • Close and check alignment
    • Repeat as needed to gain desired position
    • Properly torque bolts
    • Enjoy your properly positioned hood that no longer torments your OCD senses. :thumbsup:
  9. Dec 12, 2017 at 2:35 PM
    89hatcher
    89hatcher Well-Known Member
    check the rubber adjuster on the front of the hood. you can turn it to adjust it.
    shakerhood likes this.
  10. Dec 12, 2017 at 2:49 PM
    Justin85
    Justin85 Well-Known Member
    Justin
    mine is like that, sits flush at the front on both sides and flush on the drivers side and 1-2mm below the edge of the fender on the passenger side near the windshield.
  11. Dec 12, 2017 at 2:53 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Pics or it didnt happe
    I'm curious to see what you are referring to.
  12. Dec 12, 2017 at 3:12 PM
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    The hood stops are adjustable on almost all cars for this exact reason.
    Just unscrew the stops a 1-2mm up until hood is flush.
  13. Dec 12, 2017 at 5:59 PM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
  14. Dec 12, 2017 at 6:15 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    You’re an engineer huh?
  15. Dec 12, 2017 at 7:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My hood sits flush back towards the windshield but does sit a little low towards the front, just haven't got around to adjusting the rubber bumpers yet, no big deal...
    Whitetail Assassin likes this.
  16. Dec 12, 2017 at 8:02 PM
    SNIPES760
    SNIPES760 Well-Known Member
    Manny
    2016 White Tacoma TRD Offroad 4x4
    Maybe a washer (or 2) can fix the issue near the windshield?
    cruxofthebisquit and Toytaco2k17 like this.
  17. Dec 12, 2017 at 8:24 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Since the hood is quite a bit larger than the fenders, it is perfectly logical that the hood might not flush with the fenders.
    The toilet pictured below would probably be able to handle the fenders one at a time, but the hood is definitely too big.
    However, if you already tried to flush the hood with the fenders, you might need this:
    :rofl:
    06trdtaco and beertimecontinuum like this.
  18. Dec 12, 2017 at 8:29 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Hecho en Mexico, not all bad, I realigned my bed easy enough and tried to get worried about the hood but gave up. Couple of tequilas, no worries.
    Wsteven likes this.
  19. Dec 12, 2017 at 8:38 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Gotta perform the marble test.
    Roll a marble down the gap line between the fender and hood. If it lines up the marble will stay in the line. If not it’ll fall out and roll away...
    Works on Mercedes and BMWs.
  20. Dec 12, 2017 at 8:40 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Hmmm, the marble test? Sounds like it's the gold standard. :rolleyes:
    Yeah, I guess I'm shit posting...:rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Sandman614 and nDub[QUOTED] like this.
