Hood Open Alert?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Critical05, Jan 26, 2018.
  1. May 19, 2022 at 9:26 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Was that a warranty?
    shakerhood[QUOTED] likes this.
  2. May 19, 2022 at 9:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Na'h just my POS 76 VW Rabbit, not sure what exactly caused the latch to let go.
  3. Aug 17, 2022 at 11:58 PM
    My1Yoda
    My1Yoda Well-Known Member
    Alex
    2022 Lunar Rock Tacoma TRD OR
    Does anyone know if the hood alert turns off on the dash if the vehicle is off? I was working on my headlights and left the hood open overnight. Hopefully my battery doesn’t drain too much.
  4. Aug 18, 2022 at 5:46 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    Yes, it turns off. Takes 10-15 minutes. You can close the hood latch with a screwdriver to 'fake' a closed hood (the switch is built into the latch). Just make sure to open it with the hood release before dropping the hood.
    My1Yoda[QUOTED] likes this.
  5. Aug 18, 2022 at 9:35 AM
    My1Yoda
    Alex
    Oh okay thanks for the info.i appreciate it!
  6. Jan 20, 2024 at 4:34 PM
    99 10 11 19 Tacos
    99 10 11 19 Tacos Member
    NorCal
    2019 TRDOR AC white
    Stock
    Thanks for the info on the 10-15 min timeout on the dash display.
    I tried sticking a screwdriver in to the hood latch assembly and it kept slipping - apparently it needs a hella lot of pressure to get the latch/switch to rotate.
    I can live with this while having a Battery Tender charger clamped to the battery posts.
  7. May 19, 2024 at 7:55 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Is there a way to make use of this "feature" to switch on an under hood light for night time needs? Some sort of wiring harness and a relay to power for the lighting perhaps
