Hood Problem (Sport Hood)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leveltwo, May 22, 2011.
  1. May 22, 2011 at 4:39 PM
    leveltwo
    leveltwo [OP] Well-Known Member
    I was reading this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/158228-couple-issues-my-new-truck.html
    and noticed i have creases on the rear of my scoop as well, I looked under the hood and found several brace points (connected with some sort of glue) were not connected and i could push up on the hood with my finger from the inside...
    Is this an issue the dealer will correct? Im really looking at those dents now..
  2. May 22, 2011 at 4:42 PM
    OZ-T
    OZ-T You chose ... wisely
    Peter North
    British Columbia
    The creases are normal
  3. May 22, 2011 at 4:52 PM
    leveltwo
    Why is the glue separated from the hood then?
  4. May 22, 2011 at 5:25 PM
    OZ-T
    Peter North
    British Columbia
    I said the creases were normal .
    You got warranty left , go to the dealership .
  5. May 22, 2011 at 8:06 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Normal,
  6. May 23, 2011 at 8:43 AM
    OZ-T
    Peter North
    British Columbia
    The expression " crease " makes it sound worse than it is , it is a deliniation of where the scoop meets the hood and can only be seen in certain light .
    It is normal and you probably haven't noticed it yet .
  7. May 23, 2011 at 12:10 PM
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    I can see the one on the drivers side in your pic
