Hood quicklift system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sb0623, Sep 22, 2023.
  1. Sep 22, 2023 at 7:28 AM
    sb0623
    sb0623 [OP] Well-Known Member
    DFW
    2022 Toyota Tacoma TRD Sport
    Limo tint, hitch step, grill guard, chrome running boards, running board lights, bed cover, dash cam, interior LED bulbs, MBRP cat back dual exhaust w/chrome tips, MillerCAT cat shield
    Has anyone on here installed it on a 2022? If so, which one did you choose, and why did you choose it?
  2. Sep 22, 2023 at 8:30 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Do you mean hood struts? I added the Spiker Engineering struts. Very Happy. Added open height was a plus.
    TRDRed, SpikerEng and BillyE like this.
  3. Sep 22, 2023 at 8:31 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    16-23 is all the same. I went with their +7 kit. Fantastic, as expected from Redline.
    Also has no issues clearing the auxiliary fuse block I installed later after the previous pic was taken.
    Ahomeofbones and TRDRed like this.
  4. Sep 22, 2023 at 9:56 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Anyone know if someone makes extended struts where they’d also open to normal height?
    My carport ceiling so too low for extended but it’d be great to have the option to push it open further.
  5. Sep 22, 2023 at 10:10 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I don't believe such a thing exists... by sheer design, struts only extend to 1 length.
    You could add a limit strap... but aside from that, I'd just get the standard height. I've never had an instance where that's not high enough.
  6. Sep 22, 2023 at 10:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I'm 6' and I never had a need for greater hood opening height. With a lift and 35" tires, I need a step stool to reach some parts of the engine.
    If you're doing major work like supercharger installation, you can loosen the 4 hinge bolts and remove the hood.
    helix66[QUOTED] likes this.
  7. Sep 22, 2023 at 10:17 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I installed Redline struts. Very happy with them. Open a little more than with rod. Don't have a need or see why extension would be needed. Have to drill holes but no problem. Pop rivets can be a challenge unless you have strong hands. Recommend getting inexpensive adaptor for power hand drill.
    TRDRed likes this.
  8. Sep 22, 2023 at 10:17 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    What poundage do these usually run for a hood?
  9. Sep 22, 2023 at 10:34 AM
    canuck guy
    Alberta
    23TRDOR
    Maybe I'm slow. Don't understand your question.
  10. Sep 22, 2023 at 10:35 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
  11. Sep 22, 2023 at 10:44 AM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I really wish Toyota would do this as OEM. I really want to get hood struts. However, I know that after 5 or 6 years, they’re going to need to be replaced. All I could hope for at that point, is that the company that made them is either still in business, or i’ll be drilling yet more holes to install a different set (which I really do not want to do). Might have to poke around and see how long Redline has been around…
    JmsWms likes this.
  12. Sep 22, 2023 at 10:46 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    I also run the redline struts and find them to be very good. I had to switch my powertray, though.
    I was using the powertrays spod mount which mounts the sPOD on the fender side and leaves a giant open space on the left. The strut didn't have enough clearance with the sPOD. I ended up just switching it out for the dual version and mounting the spod on the left. You could also just drill it out but I'm anal.
  13. Sep 22, 2023 at 10:48 AM
    canuck guy
    Alberta
    23TRDOR
    Don't know why they wouldn't last as long as oem on cars that have them. I had a 2006 Honda Accord that one of my kids has and the hood struts still work fine.
    oconnor and KY_Rob[QUOTED] like this.
  14. Sep 22, 2023 at 11:23 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Redline has been making hood struts for Tacomas for 15 years or so.
    When the struts fail, you can revert to using the prop rod like the millions of other Tacoma-driving peasants.
    TRDRed, drizzoh and KY_Rob[QUOTED] like this.
  15. Sep 22, 2023 at 11:51 AM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I read that last line too fast...
    :annoyed:
  16. Sep 22, 2023 at 11:52 AM
    KY_Rob
    Rob
    North East Ohio
    Your luck has been way better than mine with those. Had a 2007 Honda Crosstour, and they needed replaced after 6 years. 2002 Jeep Liberty needed new ones every 2 or 3 years, hood and rear glass.
  17. Sep 22, 2023 at 11:54 AM
    KY_Rob
    Rob
    North East Ohio
    But the point of spending the extra cabbage is to not have to be a peasant ever again. Probably a good sign that Redline is going to be around for a while. Thanks for that info!
    3JOH22A[QUOTED] likes this.
  18. Sep 22, 2023 at 12:18 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    My 2010 4Runner has original struts for the hood and rear hatch, as does my father's 2011 Subaru.
    Funny enough replacement hood struts for the 4Runner are only $5 from Sachs: https://www.rockauto.com/en/moreinfo.php?pk=4674333&cc=3307198&pt=1404
    KY_Rob[QUOTED] likes this.
  19. Sep 22, 2023 at 1:46 PM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I installed the Red Line and my mechanic and I love it. It has more height than the original prop rod.
  20. Sep 22, 2023 at 3:36 PM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    SpikerEng likes this.
