Hood rattles
Discussion in '1st Gen. Tacomas (1995-2004)' started by glamis3000, May 14, 2011.
  1. May 14, 2011 at 1:27 PM
    glamis3000
    glamis3000 [OP] Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    ok so when im driving usually over 40mph my hood will start to rattles like it is undone. most people think its going to fly up, when im on the freeway doing 70 its pretty bad. I am not sure if this is common but its done this since i got it a year ago and its annoying. i took off the bug guard thinking it was that, and it helped but it still rattles.. ive checked bolts and tightness, i think its the latch but how do i fix this?
  2. May 14, 2011 at 2:24 PM
    mcguire
    mcguire Well-Known Member
    andrew
    Rothesay New Brunswick, Canada
    99 tacoma
    sky jacker leaf pack,crappy crap spacers,3"body lift,33" trail diggers,K&N intake,magnaflow muffler and high flow cat.
    Would like to see what you come up with, i have the same problem. I also have a bug deflector
  3. May 14, 2011 at 7:23 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Mine rattles too until a day or two ago i found that the rubber pieces (two) where the hood sits is adjustable and i raised them so the hood wont rattle.
  4. May 14, 2011 at 8:45 PM
    glamis3000
    Brant
    Cottage Grove OR
    mcguire: i ditched my bug guard awhile ago due to it causing the hood to rattle worse..
    hmm I will investigate that in the morning and see if that helps.. thanks anthony ill let you know if that solves my problem...
  5. May 14, 2011 at 9:18 PM
    Anthony250
    Anthony
    San Gabriel Ca
    yeah , its where the hood sits, you just twist them outwards , all you have to do is pop the hood and twist them and done
  6. May 16, 2011 at 1:09 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Mine rattles a bit while offroading or hot bumps. I first cranked the lil rubber do-hickies but the fender lines and hood line did match up well. So lowered em and just wrapped a lil tape around hood part that goes on the latch. I would like to know a reason this happens, doesn't look like anything can move or really bend....
  7. May 16, 2011 at 8:45 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    mine was doing the rattling around on the freeway too. i would just sit there and stare at it on road trips -- bugged the hell outta me. but i was able to adjust those little rubber stops and get it perfectly tightened. it took a little trial and error to get the hood to line up right with the fenders and still be held securely, but i was able to without much fuss.
    i hate to say it, but i was more excited about fixing that than installing my auxiliary fuse block, which i installed at the same time! :)
