Hood release cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by Diddy Spicebush, Jul 11, 2020.
  1. Jul 11, 2020 at 11:25 AM
    Diddy Spicebush
    Diddy Spicebush [OP] Well-Known Member
    Brent
    Saco Maine
    2003 sr5 2wd x-cab,and 2017 6/spd m/t sport
    Yakima roof and bed rack and tubular rear bumper.
    How much of a pain is it to change the hood cable? It hasn’t broken yet but it is on its way out.
  2. Jul 11, 2020 at 12:40 PM
    gumbo-taco
    gumbo-taco Well-Known Member
    NC
    2004 DC Offroad
    Is it not “popping” up the hood? Still able to lift the hood from the front, then release with the lever? Mine started sticking a couple of weeks ago. Felt like the cable was broken. Turns out the release latch/spring was sticking. A little dousing of spray lube got it functional again.
  3. Jul 11, 2020 at 12:41 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Last owner of mine put hood pins on it and I love em. Screw the hood cable and release
  4. Jul 11, 2020 at 12:48 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If your old one is still there, it's easy. Tape the new one to the old one and pull the new one thru the fire wall with the old one. I found it was easier to pull into the cab.
  5. Jul 11, 2020 at 1:08 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It really depends on how you define pain.
    To some of us no big deal someone else it turns into a week long project with a visit from the Fire Company
    Myself Remove the door and the seat just to remove the handle
    koditten likes this.
  6. Jul 11, 2020 at 1:11 PM
    Diddy Spicebush
    Brent
    Saco Maine
    Yes the cable is still there and it still opens the hood. The problem is once I pop the hood the cable sticks in the housing and the latch won’t close and the lever under the dash doesn’t retract. I have to go into the latch and hit the locking lever on the latch to get the cable to release. Yes I know everyone says spray the latch and it will loosen up and work but it doesn’t. I got help one day by someone pulling the lever and popping the latch while I sprayed into the cable housing. It worked fine for 6 months and then crapped out again.
  7. Jul 11, 2020 at 1:21 PM
    koditten
    Kirk
    Central Michigan
    Yep, its pretty common for them to do exactly as you are describing. Sound like your cable is fine.
    The lock assembly is only $35 on Amazon or Rock Auto.
  8. Jul 11, 2020 at 1:38 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I should get one those if I ever get around to working on my own truck
