Hood Scoop Removal and Dissasembley
Discussion in '2nd Gen. Tacomas (2005-2015)' started by southerntaco889, Aug 5, 2010.
  1. Aug 5, 2010 at 11:51 AM
    southerntaco889
    southerntaco889 [OP] Well-Known Member
    Bartow, GA
    07 PreRunner DC TRD Sport
    5100's @ 2.5/285 BFG A/T's/blacked-red badges/strobes/siren/PA/roof rack soon to come/brush guard soon to come
    ya'll i need some help. i want to install some Whelen Tir6 led's in my hood scoop for fire dept use but i cant figure out how to get it off. i saw a few links in a post someone else did on this but it still didnt make sense. can anybody give me like a step by step way to get it out and take it apart?
    Thanks in advance
  2. Aug 5, 2010 at 11:54 AM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    there was a post on here i saw a while back but i couldnt find it it was probally in something not related to taking the hood scoop apart
  3. Aug 5, 2010 at 12:00 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Post pics of this with the lights going when you finish I would like to see it
  4. Aug 5, 2010 at 12:08 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If Im not mistaken there should be 5 bolts you need to unscrew then there is a 6th one that is just a phillips head and there will be a plastic clip underneath it that you can see but its part of the setup. After you unscrew all 6 from under the hood, it should pop right out or maybe with a little wiggle.
  5. Aug 5, 2010 at 1:35 PM
    southerntaco889
    Bartow, GA
    Will do, I also have hideaway strobes and planning on puttin some more TIR3's behind the billet grille that i hope will just magically appear one day without me paying for it!
  6. Aug 5, 2010 at 1:37 PM
    southerntaco889
    Bartow, GA
    Where is the phillips head one? i took the other 5 off but didn't see that one. I guess thats why it wouldn't come out.:D
  7. Aug 5, 2010 at 1:38 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I believe its on the top towards the front of the hood. It is inside a small hole so you might need a flashlight to look for it but its there, trust me.;)
  8. Aug 5, 2010 at 1:41 PM
    southerntaco889
    Bartow, GA
    K thanks man, i'm bout to go run out and try it real quick. I'll let you know how it turns out.
  9. Aug 5, 2010 at 2:46 PM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    FYI... When I removed mine, the bolt was not coming out. In fact, the bolt was spinning inside the hood scoop that eventually they came apart but the bolt would not come out through the sheet medal of the hood itself. Be careful. If you're having problems, then don't force it. I had to force the hood scoop over the bolt to pop it out. Then find other means of taking the bolt off. I wish I had pictures of my past headache. Sorry man.
    When you go to pull out the little screw, don't lose the nut/clip (whatever it might be) behind it. If so, it will slide down the hood. You'll need a magnet of some sort to pull it out. Good luck.
  10. Aug 5, 2010 at 6:30 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    :popcorn: Subscribed
  11. Aug 5, 2010 at 6:36 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
  12. Aug 6, 2010 at 7:32 AM
    southerntaco889
    Bartow, GA
    And here's the final product. Didn't have any problems other than almost all the holes that the bolts threaded up into had stripped out. The fiberglass the scoop is made of seems really brittle so be careful if anybody does it. Just pulled all the bolts out of it, added some miracle jb weld in the holes and reinstalled the bolts and voila! Thanks to wwfirefighter for that phillips head tip, i would have never seen that and probably would have tore up all kinda s**t gettin it out:D.
    DSCN1243_c1a69fbf75a952a0ac8d138fba448c38073e5b0a.jpgDSCN1240_405f55b965a26dc910f8dd8049a18c549e56869f.jpg
    You know you have really screwed somethin up when the hood is popped and you got out your dremel and a pop rivet gun.:eek: O, and since i'm so cool I can't figure out how to embed a video in the post here's a link to my lights runnin. Don't crack on my strobes, they actually to run in a pattern the camera just makes em look FUBAR cause the frame rate isn't fast enough.http://s891.photobucket.com/albums/ac114/coopdawg889/?action=view&current=DSCN1242.mp4
  13. Aug 7, 2010 at 5:51 AM
    Cape Codder
    Jack
  14. Aug 7, 2010 at 6:34 AM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    That's friggin cool. If I'd kept my scoop hood (and, oh yeah, joined a VFD) I'd totally do that.
    You going to strobe your fogs too? That'd be cool if you could have them alternate, ie Left fog/right headlight, then right fog/left headlight.
    You do all the work yourself, or just have the department mechanics fiddle with it?
  15. Aug 7, 2010 at 8:09 AM
    MNTaco
    MNTaco Newbee
    Twin Cities, MN
    2010 DoubleCab TRD Sport Long-Bed
    Bet mat, bug shield, running boards, tonneau cover
    Exactly what I was thinking. Really cool mod. I'm envious.
  16. Aug 10, 2010 at 8:35 PM
    southerntaco889
    Bartow, GA
    Legalities, schmegalities. I had strobes before I ever even thought about getting on the FD. I'm probably wrong but if i'm not bad mistaken you can run ambers without a Emergency Lighting License.
  17. Aug 10, 2010 at 8:37 PM
    southerntaco889
    Bartow, GA
    I'm probably gonna strobe those out too at some point, just not now cause of funds:(. But yeah I did all the work myself. I love messin with this kind of crap. I'm a FD junkie. Anytime I see flashing lights I start drooling and debating whether or not to follow them:D. My girlfriend is all the time gettin on to me sayin i'm gonna run in the ditch staring. HAHA............maybe
  18. Dec 6, 2010 at 10:57 PM
    acdronin
    acdronin Well-Known Member
    Hey it's the "Kit" truck!!! Where's Hasselhoff?
  19. Dec 7, 2010 at 1:36 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    My 07 4x4 POV
  20. Dec 20, 2010 at 7:21 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Is that all we get!?
