Hood shakes at highway speed.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreidasBoss, Aug 6, 2022.
  1. Aug 7, 2022 at 9:33 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
  2. Aug 7, 2022 at 9:52 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    check the bump stops on either side. You may need to twist them up
    FreidasBoss[OP] likes this.
  3. Aug 7, 2022 at 10:10 AM
    FreidasBoss
    FreidasBoss [OP] Well-Known Member
    PA
    2020 TRD Sport 4x4 DCLB
  4. Aug 7, 2022 at 10:33 AM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    Don't blame it. You gotta shake sometimes. Life is too short.
  5. Aug 8, 2022 at 12:11 PM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    RushT[QUOTED] likes this.
  6. Aug 8, 2022 at 12:36 PM
    manwithtools
    manwithtools Well-Known Member
    Dan
    So Cal - San Diego
    2021 Cement Gray Off Road
    Fox 2.5's Deaver Stage 2. 5.29's, 285/70/R17 Front E-Locker
    It also happens to the tailgate exterior skin, it separates from the inner bracing (or was never glued). Might take a look at that area too. Just remove the inside tailgate plastic cover.
  7. Aug 14, 2022 at 11:48 AM
    FreidasBoss
    PA
    Well that’s annoying too. I’ll have to check the tailgate too. Thanks!
  8. Aug 14, 2022 at 1:55 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    whenever i wash my truck my hood flexes a ton in the center. I need to add some NVH .
  9. Sep 20, 2022 at 1:49 PM
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    I just did the 3M NVH 4274 application. It's a black urethane. More solid than the factory applied foam. It does not expand at all. I was caught off guard when first started to apply it but went for it anyways because 3M makes it just for this use.
    Product:
    https://www.3m.com/3M/en_US/p/d/b40071607/
    Good vids on application. Good tip to check that product is coming out evenly from both tubes before applying, incase one is dried out or seized up.
    https://www.youtube.com/watch?v=t05FVKGvx4g
    https://www.youtube.com/watch?v=Ye_Va8YYOdA
  10. Sep 20, 2022 at 2:02 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I've had this problem on previous cars and adding hood struts helped eliminate the issue. I have struts on my truck and do not have this issue, if that helps.
    oconnor likes this.
  11. Sep 20, 2022 at 2:26 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Why take the time to spot-weld when you can glue it faster and cheaper. Reliability costs money dammit!:bananadead:
