Hood support strut / upgrade from support rod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adkchip, Feb 11, 2024.
  1. Feb 11, 2024 at 12:45 PM
    kaljam
    kaljam Well-Known Member
    Bill
    New Hampshire
    2023 TRD Sport wind chill pearl
    I am also fighting with this - the thought of drilling and riveting doesn't sit well. But the Skokies seem to have problems after a while with the sheet metal flexing at the fender mounting location. I am considering using rivnut type fasteners instead of rivets to make the drill type look a little more professional. Not sure yet.
  2. Feb 11, 2024 at 12:59 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    There's nothing unprofessional about rivets. Rivets are holding your frame together from the factory... I would highly recommend avoiding rivnuts and installing Redlines or Spiker per their manufacturer instructions. The drilling and rivets are a super minor effort. Don't over think it.
    TacomaCZman and musicisevil like this.
  3. Feb 11, 2024 at 1:05 PM
    kaljam
    Bill
    New Hampshire
    You're right - I need to lighten up!
    Jaragon, musicisevil and Bertw192 like this.
  4. Feb 11, 2024 at 1:05 PM
    Empty_Mags
    Empty_Mags Active Member
    2022 Lunar Rock Tacoma Trail
    I did the drill/rivet option as well. Was nervous doing it but seems to have held up well so far. I like them quite a bit. For sure an un-sung hero mod.
  5. Feb 11, 2024 at 1:08 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Not quite my point, but I'll take it. :rofl:
  6. Feb 11, 2024 at 1:31 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Let’s flip this around a bit. Has anyone tried a longer hood prop from another vehicle? Had to do some mud and dirt cleaning last night and ended up using a tree branch to get it up higher.
  7. Feb 11, 2024 at 1:40 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I did the drill/rivet ones too...The Quick-Lift ELITEs.
  8. Feb 11, 2024 at 1:57 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    rivets hold all airplanes together. Just saying
  9. Feb 11, 2024 at 2:34 PM
    JTScribe52
    JTScribe52 Well-Known Member
    Dan
    2018 SR5
    I installed Spikers yesterday. Increased hood angle is well worth it.
    Any way to post a video?
  10. Feb 11, 2024 at 3:55 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    oh, that was probably in the instructions, wasn't it.
  11. Feb 11, 2024 at 3:57 PM
    2Shoes
    2Shoes Well-Known Member
    2021 TRD Off-Road
    After all the research I did on these, I just ended up with the Redline ones, drilled and riveted them, but I have a Milwaukee Rivet Gun, and lots of experience with rivets so it was an easy upgrade. I get asked about them everywhere I go when the hood is up by other Tacoma folks.
    musicisevil likes this.
  12. Feb 11, 2024 at 4:00 PM
    soundman98
    NW Indiana
    i found the spiker versions to be plenty long enough. i'm 6', and basically need to jump up to grab my hood to close it. it really comes down to just checking positioning of the 2 ends, and verifying that there's enough closing clearance that it won't bind. i found more issues with avoiding obstacles under the hood, and imagine a longer strut would impose more restrictions on locations due to things like add-on fuse boxes and battery height, or on the passenger side, the washer reservoir.
    TacoManOne likes this.
  13. Feb 11, 2024 at 4:21 PM
    2Shoes
    2021 TRD Off-Road
    Here's my question for you, what holds an aircraft together in flight? Rivets. The rivets on the hood struts are hidden under the plastic panels along the side of the engine bay so it doesn't look bad at all, you don't even see them once they are installed, and every person who doesn't have them comments on them. It's a proper fix for something that should have been on a $40K truck.
  14. Feb 11, 2024 at 6:30 PM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Redline also makes the Max version of their quick life for an extra 7” of lift. It’s pretty damn high then
  15. Feb 11, 2024 at 7:09 PM
    #35
    Tcodyw88
    Tcodyw88 Well-Known Member
    Cody
    El Segundo, Ca.
    2020 TRD offroad
    My buddy did that too, he can’t open the truck hood in the garage because it goes so high up it hits the garage door when it’s open lol.
    Jaragon likes this.
  16. Feb 11, 2024 at 7:29 PM
    #36
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    I would go with a broom handle if I needed it higher. I remember GM had a problem with their hoods on the square bodies and the hoods bent in the middle.
  17. Feb 11, 2024 at 7:34 PM
    #37
    soundman98
    NW Indiana
    i've got much of the same problem. but my garage is so low, the stock prop rod won't clear. i put some adhesive gasket foam on the part of the overhead door the hood makes contact with
    TacomaCZman and Tcodyw88[QUOTED] like this.
  18. Feb 11, 2024 at 7:35 PM
    #38
    BlackTyRD
    BlackTyRD Well-Known Member
    Tyler
    Washington
    2023 Black TRD Sport DCLB
    S&B intake, MBRP exhaust, Black Rhino Shogun wheels, tail lights, VLED footwells, bed stiffeners, side mirror turn signal lights, interior lights, X-Trek grille, Tinkerer shift knob, TRD skid plate, OEM bed lights, OEM remote lock tailgate, blackout door handles, window tint, hitch pod light, oversized cup holder, RAV4 knobs, RetraxPRO XR cover
    I installed the Sokie Tech hood struts and I'm really happy with them, but they've only been on a few months so far...
    Taco22trdor and Tcodyw88 like this.
  19. Feb 11, 2024 at 8:11 PM
    #39
    Tcodyw88
    Cody
    El Segundo, Ca.
    2020 TRD offroad
    Smart move. He has to close it from the fender side cause he can’t reach the center of the hood anymore either lol
    soundman98[QUOTED] likes this.
  20. Feb 11, 2024 at 8:15 PM
    #40
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I have the Spiker strut kit, no issues drilling, just paint the drill holes, install the rivets, and brackets, and fluid film the front and backsides, no corrosion issue, have had them in almost 5 years. Probably the best mod I've done to the truck. Pop the hood release, unhook the secondary latch, lift... The struts do the rest. Close hood when done, no bumbling, or fumbling with prop rods. Ski
