Hood support strut / upgrade from support rod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by adkchip, Feb 11, 2024.
  1. Feb 12, 2024 at 5:20 AM
    #41
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    PopRivets aren’t holding the frame together …….QUITE a bit of difference.
    RIX TUX likes this.
  2. Feb 12, 2024 at 5:22 AM
    #42
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    That was a neglect issue. The hinges would get stiff due to lack of lubrication. But yes, many square bodies with jacked up hoods
  3. Feb 12, 2024 at 11:55 AM
    #43
    adkchip
    adkchip [OP] Member
    2023 tacoma sr5
    Op here, my main concern about the rivets wasn’t the rivets, but drilling holes in the fender and hood. Causing an opportunity for rust. That’s all, plain and simple
    Bertw192 likes this.
  4. Feb 12, 2024 at 12:00 PM
    #44
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I guess you didnt read my post. Ski
  5. Feb 12, 2024 at 1:22 PM
    #45
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    skidooboy and TacoManOne[QUOTED] like this.
  6. Feb 12, 2024 at 2:03 PM
    #46
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Uhhh, paint. Plain and simple.
    skidooboy likes this.
  7. Feb 12, 2024 at 3:01 PM
    #47
    andthen
    andthen Well-Known Member
    Fred
    22DCLB Lunar Rock
    TacoManOne[QUOTED] and skidooboy like this.
  8. Feb 12, 2024 at 3:15 PM
    #48
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    If you have ditch lights, make sure the 8" extra height won't push them into the windshield. Saw someone crack their windshield that way.
    andthen[QUOTED] likes this.
  9. Feb 12, 2024 at 3:33 PM
    #49
    andthen
    Fred
    22DCLB Lunar Rock
    Not yet, I'd like to have tho hood struts installed to help me evaluate the ditch light sizing and position.
  10. Feb 12, 2024 at 3:38 PM
    #50
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I have the standard Redline Elite hood struts and Rago low-profile ditch brackets with Vision X 3.7 Canons... and they're "close". I'm pretty sure the extra 8" loft will eliminate all ditch lights.
  11. Feb 12, 2024 at 4:08 PM
    #51
    Southwest Tacoma
    Southwest
    Keep in mind that you don't have to install the lift support with the full added height. Mine only opens about 3 inches more than it did with the support rod. Where you install the brackets will determine how far the hood will open.
  12. Feb 12, 2024 at 4:14 PM
    #52
    skidooboy
    central lower mich
    ^^^^^ This, you dont have to have it open to the moon but, having a bit extra lift, more than the prop rod, is pretty ok, in my book. Ski
  13. Feb 12, 2024 at 4:14 PM
    #53
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    on some vehicles they are...
    https://www.smythkitcars.com/
    eaglehawaii likes this.
  14. Feb 12, 2024 at 4:22 PM
    #54
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Yes you "can"... but hear me out...
    These struts have been designed to apply a specific force at a specific location on the hood. Due to leverage, the designed force changes as you move the hood and fender connection points.
    For example, if you leave the fender locations as designed, but move the hood connection closer to the cab, to create additional lift, there's a chance that the struts won't apply enough force to opeon the hood or hold the hood open. Likewise, if you reduce the designed opening height by moving the hood mount towards the headlights, the struts may have too much force and require too much effort to close.
    Now, in actuality, I believe you're safe, because the struts have a decent margin of error... just something to keep in mind.
    @SpikerEng @RedlineTuning
    TacomaCZman and musicisevil like this.
  15. Feb 13, 2024 at 12:16 AM
    #55
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have Spikers om my Tacoma. I have used RED Lines as well on my Mustang. I can recommend both but can tell you I prefer the Spikers as they feel better built, constructed the same but not as heavy duty looking.
  16. Feb 13, 2024 at 1:27 AM
    #56
    TacoTuesday1
    SD CA
    -it already has holes
    -holes are require for a lot of things
    -they don't make a difference
    -if it did come with struts, this is probably how they'd do it
    -there are other things on the truck, stock, that use rivets
    the point of a hood is to open wide for access
    why Mercedes has been using vertical hinges for a long time
    key deciding factor at the time of getting Spiker over Redline, or vice versa
    whichever one has the feature the other does not
    one was adjustable, able to set higher, or really anywhere you want
    and the other was not. AFAIK
    Mine is set high. Still clears ditch lights/brackets. More room to work.
    SpikerEng likes this.
  17. Feb 13, 2024 at 4:51 AM
    #57
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    My Spikers are 3 years old & no issues with them.
  18. Feb 13, 2024 at 7:45 AM
    #58
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    Installed and removed Spiker single strut drilled option I had on my truck for a while. Really, really loved the functionality but the load from the strut caused a huge gap/uneven hood which bothered me to no end.
  19. Feb 13, 2024 at 10:49 AM
    #59
    nds0000
    nds0000 Well-Known Member
    A little bit of a difference in riveting. But since you are just saying …
  20. Feb 13, 2024 at 11:10 AM
    #60
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Little bit but the concept is the same.
