hood wobbles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jonnie666, May 13, 2012.
  1. May 13, 2012 at 7:16 AM
    jonnie666
    jonnie666 [OP] Active Member
    Hamburg/Germany
    SR5 V6 TRD
    when i drive over 90 or 100 mph the hood is very wobbly.
    is there any practical solution (DIY) ?
    sorry fo my bad grammar:eek:
  2. May 13, 2012 at 7:25 AM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Make sure the hinge bolts are tight? Make sure the seal at the top edge of the grille assembly is in good condition? I've seen the hood flex with air pressure, but it shouldn't shift.
  3. May 13, 2012 at 7:26 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    You could always slow down. Just kidding, when I had the Redline struts on the hood I had a ton of hood wobble.
  4. May 13, 2012 at 7:27 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Make sure the hood is latched properly?
  5. May 13, 2012 at 7:27 AM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2018DCSB TRD Quicksand
    Emu 887x Nitrochargers Dakar Heavys, 255 85 16 ST-MAXX
  6. May 13, 2012 at 7:33 AM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Yes...
    Stop doing this ^^^ you're putting not only yourself but innocent people in danger.
  7. May 13, 2012 at 7:33 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    drive slower?
  8. May 13, 2012 at 7:45 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    i had the same issue at all speeds over about 25. i found a bolt loose on the latch. it gave the latch a fair amount of play. tightening it seemed to fix it
  9. May 13, 2012 at 7:48 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Make sure you have the two hood cushion bumpers under your hood and check if your hood lock assembly is the correct height.
  10. May 13, 2012 at 7:49 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Maybe you guys didn't notice he is from the Autobahn. It is okay to drive that fast.
  11. May 13, 2012 at 7:52 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    From Germany... drives on the autobahn.
    Frank
  12. May 13, 2012 at 7:52 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    i think in germany it is more danger to drive slowly than to go with the flow !
    I better go and look and make sure.
  13. May 13, 2012 at 7:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    it might be "Ok", but its a truck, and not really designed for higher speeds. Hood flexing at those speeds is normal. Best way to help control it is to reinforce the crossmembers under the hood. The mounting points arent going to play much o a rol in controling flex.
  14. May 13, 2012 at 8:24 AM
    jonnie666
    Hamburg/Germany
    SR5 V6 TRD
    the bolts at the latches are tighten.
    but i could the two hood cushion bumpers adjust.
    im gonna watch this tommorow morning on the "autobahn" ;)
    thank you for your help and support.
    feedback tommorrow !
  15. May 13, 2012 at 8:30 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    lol the Autobahn is a road not a country.
  16. May 13, 2012 at 8:34 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    I would move to the Autobahn if it was a country. Maybe even settle in a town called Nurburgring. :)
  17. May 13, 2012 at 9:45 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Hood pins fixes the problem.
  18. May 13, 2012 at 9:49 AM
    06ryan27
    06ryan27 Well-Known Member
    Aiken, SC
    12 DBL 4x4 SPORT
    3" RBP lift, anytime fogs
    Last thing I would be doing is taking a picture at 110
  19. May 13, 2012 at 9:50 AM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    Amen to that!:D
  20. May 13, 2012 at 9:56 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I was also rubbing one out and driving with my knee if it makes you feel any better, and the speedo is off it was more like 120.
    Also nuerburg is a real town, with a nice track around it.
