Hood won't open after changing out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Mar 22, 2023.
  1. Mar 22, 2023 at 4:25 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Did the 2.5 swap a few weeks ago but I'm just now getting around to opening the hood, but nothing happens when I pull the handle. I did buy an aftermarket hood like a dummy, but I did a test fit before I screwed it down and it was opening fine. Now that it's completely installed it won't open at all. I'm sure it's something quick and easy, but I'm probably too dumb to figure it out so here I am.
  2. Mar 22, 2023 at 4:32 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Latch is probably stuck. Pull the cable and have someone press down on the hood a few times. That doesn’t work try to shoot it with some WD40 or penetrating oil
    Geeves77, 10thMTNgrunt and tcjacado like this.
  3. Mar 22, 2023 at 8:53 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Like was said above try that then adjust the bumpers on the front to keep from jamming the latch.
  4. Mar 23, 2023 at 8:53 AM
    drewskie
    Drew
    Burbank, CA.
    Thanks. I think I might be screwed, it's not budging. Might have to drill out the latch.
  5. Mar 24, 2023 at 5:14 PM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Try getting a helper to pull the hood release in the cab a few times and keep doing it or hold it while you apply upward pressure with your fingers pulling up on the front edge of the hood near the latch. If this doesn't work push down on the front edge of the hood a few times, then repeat the above.
    I have had this problem on the wife's Volvo S70 for years. I have to pull the release (won't pop up) and then go around to the front and use upward pressure to get it to pop. Sometimes it takes two or three repeats.
    If this doesn't work, before drilling it out, try crawling under the bumper and applying upward pressure to the underside of the hood with something that is long enough to reach it while the helper works the latch. (stick, short broom handle, snow brush handle, etc)
