Hood won't pop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TRDOFFROAD, Jul 17, 2013.
  1. Jul 17, 2013 at 10:05 AM
    08TRDOFFROAD
    08TRDOFFROAD [OP] Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Hey all,
    Been having this issue with the truck for a while. When I try to pop the hood, the latch will release, but the hood will not pop up the 1" or some to reach under and release the latch completely. I have to pry my fingers in the corner of the head light to lift the hood. Any idea on what is wrong and how I can fix this?
    Thanks!
    JoeManji likes this.
  2. Jul 17, 2013 at 10:08 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Did you check the wire to see if it was loose or not?
    HokieHT07 likes this.
  3. Jul 17, 2013 at 10:10 AM
    08TRDOFFROAD
    Dan
    The lever in the cab releases the hood and the cable appears to be okay, the hood just doesn't "pop" up the inch or so it used to to allow to get underneath to release the lever completely.
  4. Jul 17, 2013 at 10:12 AM
    Monster Coma
    Corey
    Check all the bolts on the latch to make sure they are tight? Perhaps the spring is weakened
  5. Jul 17, 2013 at 10:14 AM
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    my 07 used to do this, I think it is the hood getting stuck to the rubber gasket that goes around the headlights and grill. it was very annoying to deal with, of course I never found a remedy, so I will be watching this thread
  6. Jul 17, 2013 at 10:14 AM
    169.254.255.201 Well-Known Member
    Interwebs
  7. Jul 17, 2013 at 10:24 AM
    BARTRD
    BARTRD Well-Known Member
    Brian
    Monroe, Ga
    '07 RR TRD Sport
    Volant CAI with optional skoop, Magna-Flow exhaust, K&N drop-in air filter, WeatherTechs, Wet Okole, kenwood navigation head unit, de-badged, 15% tint all around, factory roof rack fitted with Thule fairing, billy 5100 on all 4 corners, ICON AAL, n-fab light bar with 4 hella 500s, rear lights mounted under bumper
    My 07 does the exact same thing
  8. Jul 17, 2013 at 10:53 AM
    08TRDOFFROAD
    Dan
  9. Jul 17, 2013 at 12:05 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    My '05 did this, and I'd have to virtually peel back my fingernails to get under the edge of the hood to pop it up to get to the secondary latch. It's the two rubber bumpers on the hood that need adjusting. One on each front corner. Give it a 1/4 turn counter-clockwise, slam shut and pop hood. If it doesn't pop up, give another slight adjustment and test until it does. Very very easy to fix and I was pissed that it took me so long to figure that out.
    hokiehunter19, ericvega, mk5 and 3 others like this.
  10. Jul 17, 2013 at 12:16 PM
    08TRDOFFROAD
    Dan
    If that fixes my issues, I will have the same emotions! ha ha!
  11. Jul 25, 2013 at 6:16 AM
    08TRDOFFROAD
    Dan
    Adjusting the rubber bumpers solved the problem! The hood now functions like it should! Thanks guys!
    Rock Lobster and JKU3000 like this.
  12. Jul 25, 2013 at 6:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :woot:
    My 2007 has been doing that to me for a long time!
  13. Oct 12, 2014 at 12:50 PM
    DJBRocks757
    DJBRocks757 Member
    DJ
    Hampton, Va
    2007 access cab 4 banger 5 speed
    +1 for the adjusting rubber bumpers! I've dealt with this for the past 2 years! No tools required and took 30 seconds!
    08TRDOFFROAD[OP] likes this.
  14. Apr 28, 2015 at 7:25 PM
    Azazruk
    Azazruk Well-Known Member
    NJ
    Greatfull to find this fix! Has been a fustration for way to long. Thanks for the help fellas
  15. Jan 12, 2017 at 6:10 PM
    TakeMeToTheTacoShop
    TakeMeToTheTacoShop Member
    Arthur
    Chino Hills, CA
    2001 V6 Tacoma Prerunner TRD
    Bilstein 5100 3" Lift
    +1 for the adjusting rubber bumpers. Worked like a charm on '01.
  16. Mar 12, 2017 at 9:07 AM
    JSouthworth
    JSouthworth Member
    Versailles, KY
    2007 Dark Blue V6 Tacoma Double Cab TRD 4x4 OffRoad
    This forum has been great for me. Finding little issues I have on newly acquired 05 Tacoma has been awesome! Thanks for this thread, some in the past and in the future!
  17. May 24, 2019 at 10:33 AM
    currysteph
    currysteph Member
    Stephen
    Houston
    2004 V6 Tacoma PreRunner Dual Cab
    Truxedo Cover, Bed Liner, New Headlights, Tow Package, Tinted windows
    So for me it was this....I had changed the instrument panel bulbs in my 2004 Tacoma earlier. In doing so you have to drop the plastic facia that runs along the bottom of the steering wheel and above the gas/brake pedals. Well the pull tab for the hood is in that location as well and it turns out that the cable needs to be slid into a notch on the backside of the pull tab. During my bulb install the cable slid out from there and thus wouldnt release the hood. All I had to do was crawl up into the floorboard and slide the cable back into that notch on the backside of the pull tab. Hope that helps for someone else.
  18. May 24, 2019 at 10:37 AM
    sjc
    sjc New Member
    2015 tacoma sport
  19. May 24, 2019 at 10:39 AM
    sjc
    sjc New Member
    2015 tacoma sport
    spray wd-40 on latch . worked for my 2015 then sprayed lithium grease
  20. Mar 29, 2020 at 4:06 PM
    GOFASTT
    GOFASTT Member
    California
    Tacoma PreRunner SR5 Sport
    Doh! Of course adjust the rubber bumpers. My Tacoma is back to being perfect!
    JimIowa likes this.
