Hood Won't stay Latched Down
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Jul 24, 2018.
  1. Jul 24, 2018 at 7:13 PM
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    Any Ideas why my Hood keeps popping? I have tried to adjust the Rubber on each side of the Front of the Hood. It just all the sudden will just Pop and I have to pull over and Shut it. Then a while later it will happen again...
  2. Jul 25, 2018 at 12:30 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    the latch is probably seizing up. i dont have a picture but theres a spot on the latch you can use a screw driver and a hammer on and hit it down.. should latch then (at least that was my problem before i replaced the latch)
    Layzboy[QUOTED][OP] likes this.
  3. Jul 25, 2018 at 6:34 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Take off and clean the latch then re-grease it.
    Layzboy[OP] likes this.
  4. Jul 25, 2018 at 9:28 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Looks like a few bolts and its Off. Just one more stupid thing im dealing with.
  5. Jul 25, 2018 at 9:36 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Try loosening the latch and raise it up a tad so the hood catches sooner.
    phatius and Layzboy[OP] like this.
  6. Jul 25, 2018 at 1:12 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Maybe take the hook/loop off the hood and shove it down on the latch and see if the latch mechanism moves freely.
    Then clean and lube the latch and cable.
  7. Jul 25, 2018 at 5:06 PM
    phatius
    phatius Newb
    Los Angeles
    02’ Tacoma TRD 4x4 DC
    I had the same issue with the latch and did this. Worked for me - only problem is that if I pull hard enough on the hood it'll pop open.
    At least it's not popping up while I'm driving
  8. Jul 25, 2018 at 11:34 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Check your hood release cable. If it doesn’t snap back freely when you pull on it your hood release mechanism might be stuck, stuck on open. A temporary solution is have a hook hand tool. Use that to push the release mechanism to the right, resetting the hood latch. The mechanism is at the bottom, hooked to a steel cable. Fix it solution is to clean it. Dirt and grime will cause it to stay open. Hope this helps.
