hook up electricity to tacoma on electric campsites
Discussion in 'Off-Roading & Trails' started by tacomabiker, Mar 18, 2010.
  1. Mar 18, 2010 at 11:26 AM
    tacomabiker
    tacomabiker [OP] Well-Known Member
    Dan
    Maryland
    05 Toyota Tacoma V6 4x4 Offroad
    Leer Shell, Tow Package,
    Hey.
    I was wondering if you're camping at a campsite that has an electric hookup if you could plug it into your truck via extension cord into one of the 12 volt outlets.
    I'd like to do this like RV's do so that when the truck isn't running, you can plug it in, and still use electrical appliances (laptops, etc..) without draining the battery.
    Thanks in advance.
    Would a battery tender be ok if I connect it to the battery, and then use my electrical appliances?
    Thanks.
  2. Mar 18, 2010 at 11:29 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Not thru the factory inverter but yeah, not seeing why you couldn't have retractbale cord to plug in and feed a few recepticles in the camper or cab to pwr stuff. I'd keep it seperate from any vehicle wiring tho.
  3. Apr 7, 2010 at 5:21 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Today I tried plugging my camper into the inverter plug to charge the battery through the 3 stage converter / charger in the RV. The charger operated fine, this was the first time I had plugged in the RV this year, so the battery was fairly low. It went for 10 minutes no issues. The load indicator on my Scangauge showed a 5% (29 - 34%) increase in engine load, fuel consumption was 1.35 Liters per hour (no load / idle is 1.25LPH). This seems very fuel efficient. A good option for dry camping. No point getting a generator.
    I also tried a hair dryer on 3 different settings. 400watts, 800w, and 1200w. On 400w, I believe the inverter was keeping up fine, the truck showed 40%load, and 1.5 LPH.
    On the 800w setting, the fan on the dryer was not blowing as hard as normal, and was not generating very hot air. The inverter did not shut off though. I only tested it for 20 seconds. 43% load, still around 1.5LPH.
    On the 1200w setting, the inverter never shut off, but was not putting out anywhere near 120v. The truck was still @ 43%load, 1.5LPH.
    The indicated voltage on the truck never dropped below 13.5V, indicating that the alternator was keeping up no problem. Very cool.
  4. Apr 7, 2010 at 5:44 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Very informative post Hemi. Thanks. :thumbsup:
  5. Apr 7, 2010 at 5:57 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Hemi how are you getting up to 1200 watts i thought the inverter could only get to 400
  6. Apr 7, 2010 at 6:42 PM
    Isthatahemi
    TRD OFF ROAD
    It was not putting out even close to 1200, maybe 600ish. My testing suggested it will surge to 600watts without shutting off.
