HOOKE ROAD Roof Rack...............Ubox-offroad.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimlmackjr, Mar 14, 2019.
  1. Sep 16, 2019 at 4:50 PM
    #381
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Very cool! Thanks for sharing. I have a buddy out in Tirejas. It's freaking beautiful out there!
    ProcTheBootyDr[QUOTED] and 4sky like this.
  2. Sep 16, 2019 at 4:51 PM
    #382
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    No problem. I was the one putting on the group buy but it died quick. And it wasn’t worth it after the Putnam on the Amazon coupon. Scoop them up while you can.
    RobP62[QUOTED] likes this.
  3. Sep 16, 2019 at 4:54 PM
    #383
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I am definitely buying one. Do you know if can I order from Amazon and be guaranteed one without the numbers on the side for a 3rd Gen?
  4. Sep 16, 2019 at 4:55 PM
    #384
    Blais03
    Nick
    Easthampton MA
    I believe it’s just without numbers now. Just remember, if it fits a 2nd gen it’ll for the 3rd gen too.
  5. Sep 16, 2019 at 4:56 PM
    #385
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Is that still true with the shark fin antenna on the 3rd?
  6. Sep 16, 2019 at 5:04 PM
    #386
    Blais03
    Nick
    Easthampton MA
    I believe they changed their design to accommodate for it.
  7. Sep 16, 2019 at 5:06 PM
    #387
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Cool, I don't use it but don't want to deal with removing it or modifying it either.
    Thanks again!
    Blais03[QUOTED] likes this.
  8. Sep 16, 2019 at 5:10 PM
    #388
    Blais03
    Nick
    Easthampton MA
    No problem.
  9. Sep 16, 2019 at 5:32 PM
    #389
    4sky
    4sky Well-Known Member
    Kevin Levu
    2018 White Tacoma PRO
    Thanks for the coupon !
    LivinLoud[QUOTED] and RobP62 like this.
  10. Sep 17, 2019 at 2:22 PM
    #390
    Matt.schaefer37
    Matt.schaefer37 Well-Known Member
    Test fitting. I’m gonna make bigger brackets to level out the rack.
  11. Sep 17, 2019 at 2:28 PM
    #391
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Looks Great Matt! This is exactly what I am going to do when I get my cap. I am ordering it with the rails but no rack because I need something as close as possible to get into my garage. This is absolutely perfect.
    Now, with that said, the cap I am ordering (when the time comes) is the MX so basically 4 - 5 inches higher than the cab. I never plan on spanning them both but for the guys that do I have to ask, won't there be too much flex to secure something to them both at the same time?
    Skyway likes this.
  12. Sep 17, 2019 at 2:43 PM
    #392
    Matt.schaefer37
    Thanks Rob. I don’t do much off-roading anyways. It’ll be fine for me. If you’re getting the rails installed, the roofs gonna be stronger from the factory. You’ll be okay.
    RobP62 likes this.
  13. Sep 17, 2019 at 2:55 PM
    #393
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I just want a rack up there for a water port and solar panels. Maybe some awnings.
    I'm so glad I saw this thread and your rack mod! Again, great job!
  14. Sep 18, 2019 at 11:53 AM
    #394
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
  15. Sep 18, 2019 at 11:55 AM
    #395
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Wait did you make that cab rack or buy it?
  16. Sep 18, 2019 at 11:58 AM
    #396
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    NVM i see what you did!
  17. Sep 18, 2019 at 12:00 PM
    #397
    Matt.schaefer37
    I bought a second rack. Then, cut the rails to 3 inches. Drilled new holes. But, I’m making extension brackets out of the front fairing. It’s about an inch to inch and a half lower. I’ll post pictures of what I’m making tomorrow.
    Skyway and Brian422[QUOTED] like this.
  18. Sep 18, 2019 at 12:02 PM
    #398
    Matt.schaefer37
    I just stood on the rack yesterday and this rack is stout as can be!!!!! I’m very impressed with it.
    RobP62 likes this.
  19. Sep 18, 2019 at 1:41 PM
    #399
    er2016SR5
    er2016SR5 Member
    Arizona
    2016 Ghosttaco
  20. Sep 18, 2019 at 2:05 PM
    #400
    07TacoLA
    07TacoLA Well-Known Member
    Brad
    2007 Tacoma PreRunner DCSB
    Where did you get that grille?
    Hunterdc1 likes this.
