HOOKE ROAD Roof Rack...............Ubox-offroad.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimlmackjr, Mar 14, 2019.
  1. Jul 1, 2020 at 5:40 AM
    #901
    yorkshiredoughboy
    yorkshiredoughboy Well-Known Member
    Yorkshire
    2017 TRDORDC
    the pre-drilled holes on the rack line up perfectly with the pre-drilled holes in the fake max tracks. Bonus.
    JK, FreshPots, Biscuits and 3 others like this.
  2. Jul 1, 2020 at 2:52 PM
    #902
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    A few posts ago someone stated that these are hard to find... any availability for third gen?
  3. Jul 1, 2020 at 3:10 PM
    #903
    yorkshiredoughboy
    Yorkshire
    2017 TRDORDC
    I believe they are out of stock until August.
    bttrbsch likes this.
  4. Jul 1, 2020 at 7:34 PM
    #904
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    I just got an email from them. Mid July
    so we shall see
  5. Jul 5, 2020 at 7:55 AM
    #905
    Rhymeswithdick
    Rhymeswithdick New Member
    Nic
    2017 Quicksand Tacoma TRD Offroad
    So after weeding through only a few of the almost 50 pages here I gather the consensus on this rack is that it’s pretty good especially at the price point, but requires some mods or “tricks” to reduce noise. Can anybody point out exactly what mods those are? Thanks in advance.
  6. Jul 5, 2020 at 8:58 AM
    #906
    Juniorbpd
    Juniorbpd Well-Known Member
    MD
    '12 TRD Off Road
    Some of the other members have recommended the bulb seal (an automotive gasket) , which can be purchased on Amazon. The second recommendation is to mount the rack on the high setting in the rear and the low setting on the front of the rack to make it more aerodynamic. Personally, Ive always driven a vehicle throughout my career that had a roofrack so Im used to the sound. No matter what you put on your roof, unless its an airplane wing, it is going to make sound when youre traveling up the road. That being said, the bulb seal is cheap and is more of an insurance policy to keep your rack from scratching your roof. I plan to reset my rack to make it set on the same height front and rear because Im not sure if that's making a difference. Lastly, I bought mine on amazon. They rack is supposed to have 5 crossbars, each with a different size. For the sake of making this easy, they are labeled 1-5. They sent me 1,1,3,4,5 (no number 2 crossbar) so I complained to amazon and they refunded ALL MY MONEY. Therefore, I love the rack and can't complain not even a little bit.
  7. Jul 5, 2020 at 9:00 AM
    #907
    Juniorbpd
    MD
    '12 TRD Off Road
    Has anyone used the lights that came with the rack as ditch lights mounts on the hood with brackets? Im wondering if they will work or will be to big to open the hood if I mount them.
    PasswordIsTaco123 likes this.
  8. Jul 5, 2020 at 9:08 AM
    #908
    Lumberjackcoma
    Lumberjackcoma Well-Known Member
    Scott
    unknown
    They work, they're just typical 3" square led pods.
    Juniorbpd[QUOTED] likes this.
  9. Jul 6, 2020 at 9:45 PM
    #909
    Ausram
    Ausram Active Member
    Austin
    Eugene, OR
    2018 Tacoma TRD Off-Road DCSB
    you are correct. I put the bulb seal (with 3M wrap under to protect the paint), made the front lower than the back, AND filled in the cutouts in the front fairing with some aluminum sheeting. Even with those things it’s still noisy past 40mph. I had a very quiet Lexus before the Tacoma so I may be more sensitive than others. That being said I love the damn thing and my only regret is that I didn’t buy it sooner. After a month or so I got used to the noise and don’t notice it much anymore. I do keep my volume about 5 digits higher these days.
  10. Jul 8, 2020 at 10:58 AM
    #910
    Tpowell707
    Tpowell707 Active Member
    T
    2008 White Tacoma TRD Rugged Trail
    3" Lift 32" Tires
    remove the front fairing and replace with a lightbar. Wind noise almost gone!
    Dawdaw808 likes this.
  11. Jul 8, 2020 at 4:05 PM
    #911
    Juniorbpd
    MD
    '12 TRD Off Road
    Any recommendations on a light bar?
  12. Jul 9, 2020 at 6:05 PM
    #912
    Juniorbpd
    MD
    '12 TRD Off Road
    Are these the x-bulls?
  13. Jul 10, 2020 at 7:01 AM
    #913
    itzyoboipaul
    Paul
    PFville, TX
    2020 TRD OR Cement
    Looks like it will be in stock in 4-5 days
    so what do I really need to do to get rid of the wind noise. That’s the only hurdle that is stopping me
  14. Jul 14, 2020 at 1:07 PM
    #914
    Lyda81
    Lyda81 New Member
    Ben
    2016 Red Tacoma SR5
    3" lift. TRD wheels. Hooke Road Roof Rack.
    I'm curious if anyone has been able to mount anything to their Hooke Road Roof Rack? I tried mounting a kayak rack, but it sits to close to the roof to get the bolts and nuts on. Has anyone mounted something similar and how did you do it. Are there any racks that can be bolted directly to the cross bars?
  15. Jul 14, 2020 at 1:12 PM
    #915
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    I mounted an awning to the cross bars, just made some angle and used the existing holes.
    Juniorbpd likes this.
  16. Jul 16, 2020 at 8:12 PM
    #916
    Islandtaco671
    Daniel
    San Diego
    Anyone near San Diego looking to pick this rack up? I’d like to sell mine along with a 4’ awning!
    BoMartin88 and PasswordIsTaco123 like this.
  17. Jul 16, 2020 at 9:49 PM
    #917
    t-frax
    t-frax Well-Known Member
    Cali
    08 PreRUNNER TRD Sports Pkg, Black
    Pop&Lock, Bakflip, spare tire lock, folding hitch step, alarm, n-fab steps, more to come hopefully
    I'm not near San Diego, but just curious, why you wanna sell it and how much?
  18. Jul 17, 2020 at 4:57 AM
    #918
    Islandtaco671
    Daniel
    San Diego
    No worries! I just want to switch it up, looking to put a rack on the shell instead and I’m also looking for a bigger awning. Looking to sell both for $250!
    I wouldn’t be opposed to shipping it either!
  19. Jul 17, 2020 at 5:21 PM
    #919
    PasswordIsTaco123
    PasswordIsTaco123 Well-Known Member
    Scott
    Greenville SC
    2015 DCSB TRDOR
    2015 Silver Bullet Taco Installed: 5100's W OME887's +1/4leanspacer Toytec Boss Rear shocks Headstrong AAL + 1/2in block Ubolt Flip W superbumps Front Superbumps CB drop kit 4runner Trail Edition 17in Wheels Tires: Falken Wildpeak At3 C-load 275/70/17 Hooke Road Roof Rack Have but may/may not install Ex rear brake lines diff drop
    Yep I’ve got them as ditch lights, not bad, i opened them up and sealed the whole thing so no condensation so far
  20. Jul 17, 2020 at 5:28 PM
    #920
    PasswordIsTaco123
    Scott
    Greenville SC
    2015 DCSB TRDOR
