HOOKE ROAD Roof Rack...............Ubox-offroad.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimlmackjr, Mar 14, 2019.
  1. Aug 7, 2020 at 2:10 PM
    #941
    mjon
    mjon Active Member
    I'm in need of the same answer...
    ...anyone ...anyone?
  2. Aug 7, 2020 at 2:12 PM
    #942
    Quincyq
    Quincyq Well-Known Member
    2006 Silver SR5 V6 Tacoma
    Repainted Rims K&N cold air intake MBRP catback exhaust
  3. Aug 7, 2020 at 2:14 PM
    #943
    mjon
    mjon Active Member
  4. Aug 7, 2020 at 2:15 PM
    #944
    Quincyq
    If you planned on using all four you would probably need a four lead but I was going to start with only two light and probably mount them as ditch lights
  5. Aug 7, 2020 at 2:20 PM
    #945
    mjon
    mjon Active Member
    got it, I want to still all (4).
    Please keep us posted if you end up installing it.
  6. Aug 7, 2020 at 7:17 PM
    #946
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Have had mines on for 2-3 weeks now. Always parked in the garage and hardly driven but the both front tip is already starting to rust. Any solutions to fix this? Can I just spray paint the front tip flat black just to cover it?
  7. Aug 8, 2020 at 7:37 AM
    #947
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    My man
    MattCowsmasher and jozecuervo like this.
  8. Aug 8, 2020 at 8:02 AM
    #948
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    West coast guys theres a guy selling one in Jurupa Valley for 200 plus shipping. I won't be buying figured somebody else might want it.
    MattCowsmasher likes this.
  9. Aug 9, 2020 at 9:46 AM
    #949
    Ask about me
    Ask about me New Member
    Tyler
    2018 Grey Offroad Tacoma
    I've got one brand new in box for a 4 door Tacoma that I'm trying to sell in Greater Seattle area 250$. Not sure if it's against the rules to sell here but Pm me if you're interested.
  10. Aug 10, 2020 at 10:42 AM
    #950
    jesserider12
    jesserider12 Active Member
    Jesse
    2011 White Tacoma TRD Sport
    Here’s mine. Bought from a member on here a few weeks ago. Sanded down to remove texture and painted satin black. Also removed the font emblem and filled it with liquid metal. I like it and for the price, can’t beat it.
  11. Aug 12, 2020 at 8:40 PM
    #951
    TacoTuesday1
    SD CA
    looking to buy one if anyone wants to sell theirs!
  12. Aug 18, 2020 at 8:17 PM
    #952
    Pubs656
    Pubs656 Member
    2017 TRD OR
    Near Pittsburgh.. looking to buy one also if anyone wants to sell. Plus I have an OEM Toyota roof rack to trade.
  13. Aug 18, 2020 at 10:57 PM
    #953
    jozecuervo
    jozecuervo New Member
    Jose
    Cayucos, Ca
    '19 TRD OR
    Shell and a few MESO LEDs
    I really liked what you did, jimlmackjr so I copied the approach with a few changes. I fit to a set of rhino t-slot rails (permanently) to my shell. The rails are installed parallel, in case I change my mind on the rack or ever want to sell the shell. I made different brackets front and rear to compensate for the rack taper (1 and 1/8” offset, in case anyone was wondering). I was more conservative on cutting away material which means more weight, but I think I could still sell it as a cab rack, even the original bolt holes are all intact. The clearance is barely a millimeter from the shell at a few points, but I managed to get as close to flat and level as I think one can get. I ended up welding my brackets together to add torsional rigidity.
    The front rack had to be adjusted to front up back down to be as close to level (flat) as possible relative to the new back rack. To make the front rack fit like this I had to chop the rear footing slightly. I chopped the front tips while I was at it, then incorporated the $60 cheapo LED bar someone mentioned earlier in the thread using the same brackets from Ace.
    I’m using 2 of the LED pods for ditch lights and 2 more somewhere on the back for camp stuff. The other 4 I wired up on my tractors. it’s all started to rust already so I’ve just been hitting everything with flat black rustoleum, bolts included. Looks way better to me. I sprayed the chrome hardware on the pods with some lube, but expect to have to paint/replace those too.
    I still need to re-paint and re-install the front rack, protect the threads and chop my cab top weather stripping. Fortunately, I installed a harbor freight hoist so I can get the thing on and off less precariously. I did scratch the truck roof and shell a bit in the process so I’ve got some paint correction to do later. Wish I’d protected the roof first, maybe a wrap, but this rack should stop me from doing a lot of damage down the road. I planned to hoist the shell using the rack as an anchor point. This may prove a terrible idea, so I’m probably going to try 1 1/2” NRS straps first.
    My use case: hauling long lumber, furniture, long kayaks, long surfboards, and occasionally shuttling whitewater rafts up river (without deflating). Cheers and thanks for the inspiration.
    Alexely999 likes this.
  14. Aug 22, 2020 at 1:45 PM
    #954
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    Been meaning to post pics of the yak mounted up! Perfect for hauling the kayak when I need bed space...it's 75# hull only so to put up easily it definitely requires help but it's painless nonetheless! Top holes are perfect for the hooked cam straps I use. Yak sits still and flat even at highway speed couldn't ask for more.IMG_4727.jpg IMG_4728.jpg
  15. Aug 24, 2020 at 1:08 PM
    #955
    [SEAR]taco
    [SEAR]taco Well-Known Member
    2019 White Tacoma TRD sport dbcb
    Awesome picture! My wife wants to get paddle boards so it looks like it'll fit perfectly on the rack!
    zjcas[QUOTED] likes this.
  16. Aug 25, 2020 at 8:26 AM
    #956
    Hazard20
    Hazard20 Active Member
    Dan
    2014 Tacoma SR5
    One of the very first Covid projects. Been on since April. No leaking, and only a slight fuss to install. A couple of the holes on the brackets were not lining up with the holes in my roof rack. I had to drill out the bracket a bit before I was able to get it to sit properly.
    Any suggestions for touching up? I was considering just getting some black universal touch up lacquer paint for some of the areas that were scraped during assembly and have begun to show some rust
    Also, is it just mine, or is it nearly impossible to get this thing to sit on the Bottom set of holes to get it to be perfectly level? I see that a number of your 2nd gens its slightly raised in the back... Overall, great rack. I will be mounting an awning and pole holder in the coming weeks as well.
    BaronVonChokey likes this.
  17. Aug 25, 2020 at 9:35 PM
    #957
    jimlmackjr
    jimlmackjr [OP] Well-Known Member
    JimE
    Harker height,Tx
    Toyota Tacoma TRD Pre Runner Sport Long bed
    Tacoma beast headlight Meso mods inside lights Trd pro grill Hooke road roof rack BFG KO2 Roam RTT
    I would just hit it up with a little paint
    Ryan2103a[QUOTED] likes this.
  18. Aug 25, 2020 at 11:49 PM
    #958
    Ryan2103a
    SoCal
    That's exactly what I did. Thanks
  19. Aug 27, 2020 at 10:13 AM
    #959
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    How do some of you get black hardware, while others get silver? I'd like black personally... do I have to do a special request?
  20. Aug 27, 2020 at 10:34 AM
    #960
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I asked specifically for black hardware.
    Just a small update on the rack, mounted an OVS 180* awning a few weeks ago.
