HOOKE ROAD Roof Rack...............Ubox-offroad.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimlmackjr, Mar 14, 2019.
  1. Sep 12, 2020 at 12:38 PM
    #981
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Where did you route the wiring?
    FreshPots[QUOTED] likes this.
  2. Sep 12, 2020 at 12:55 PM
    #982
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Down the drivers side windshield channel. Super easy
  3. Sep 12, 2020 at 2:12 PM
    #983
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    Installed my rack yesterday with it set to high in the front and high in the rear. Added door seal (not the specific bulb seal listed in this thread, may have to end up purchasing that specific style).
    This rack absolutely howls on the highway. What's the verdict, should I do low front high rear? Or vice versa?
    FreshPots likes this.
  4. Sep 12, 2020 at 3:11 PM
    #984
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Just pull the front fairing off. Almost completely eliminates the noise. I had mine off for a few days before installing the light bar. Almost silents
  5. Sep 13, 2020 at 4:16 AM
    #985
    Hazard20
    Hazard20 Active Member
    Dan
    2014 Tacoma SR5
    F66B8752-48DA-49C3-8B34-60E9EEF4A0DF.jpg 9891E1E2-9CF8-4991-AE8A-690AD6374B0B.jpg Very impressed with how well this worked to carry my canoe. The perfect width, and was great to have the holes in the side to fit the cam buckle strap hooks into.
  6. Sep 13, 2020 at 7:36 PM
    #986
    Flenlips
    Flenlips short man mad
    Northwest Ohio
    2015 White 4x4 DCSB
    ARE Z Series 265/75/16 AT3W summer 265/75/16 Discoverer M+S 285/70/17 Geolandar AT G015 Ray10 Brushed Gold 17x9 -10 Ironman 4x4 HD leaf pack, 3 leaves removed Bilstein 5112 rear Rear extended lines 1.25" BORA spacer front RC Vertex 3.5" fronts Limit straps 8" front Blue Sea large Fuse Panel Hidden Winch Bumper Apex12K with cutoffs
    Love mine-- I have a bed cap and a great CB mount right now-- can post more pics if necessary.
    98180794_10158053019829564_3425042582390_129b3ebbbd0522d9e5a540f54a871b7364651561.jpg
    The bulb seal really makes this rack quiet. Highly suggest purchasing.
  7. Sep 13, 2020 at 8:04 PM
    #987
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Looking good!!
  8. Sep 14, 2020 at 9:57 PM
    #988
    tjc0010
    tjc0010 New Member
    Tyler
    2014 Tacoma Double Cab
    This is exactly what I am looking for. Got the Hooke Road rack installed recently and have been searching for an awning. What brand did you go with?
  9. Sep 14, 2020 at 10:16 PM
    #989
    bttrbsch
    Michael
    Bellingham, WA
    I went ahead and ordered the bulb seal. I originally put the Cowles edge trim on but it makes so much noise... hopefully this bulb seal does the trick. I own a third gen and can't seem to do the lower mounting position in the front and rear, so it's positioned high in the front/rear.
    So my gameplan:
    - add the bulb seal to the front fairing
    - slam the front fairing as low as it will go
    - rack mounted high position front/rear (can't bolt into lower position)
    Any other suggestions to combat wind noise?
  10. Sep 14, 2020 at 10:24 PM
    #990
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    I have mines set high in the front and low in the back. It was a tight fit to get the back to its lowest position with the roof moldings on but it evened it out and helped with the noise. I also have prinsu noise reduction edge trim which completely closed the gap from the roof rack to the car roof. It's still loud inside the car at high speeds but a lot better than before. A little hard to tell in the picture but the gap in the middle is gone.
  11. Sep 14, 2020 at 11:19 PM
    #991
    bttrbsch
    Michael
    Bellingham, WA
    Thanks for the feedback. I’ll try and lower it in the rear (might need to undo several bolts to allow it to move around better). Will try this thicker edge trim too.
    I knew wind noise would be annoying, but it sounds like a jet above my truck when I go over 35 mph!
  12. Sep 15, 2020 at 12:14 AM
    #992
    Ryan2103a
    SoCal
    Ya it was pretty loud at first but like I said it did get better when I made the adjustments. I also had to loosen all the bolts to get the back to the lowest position. I don't know how did it cuz it seemed impossible at first but I eventually got it there after messing with it for a couple hours.
  13. Sep 15, 2020 at 6:18 AM
    #993
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Check out Roam awnings. Super affordable, love mine.
    BaronVonChokey and Hazard20 like this.
  14. Sep 16, 2020 at 8:51 PM
    #994
    Juniorbpd
    Juniorbpd Well-Known Member
    MD
    '12 TRD Off Road
    I went with a super cheap option from Amazon called the yescom awning. It covers the width of both doors and is identical to the arb. I’m a weekend warrior and not professional overlander but I did watch and read a lot of reviews before deciding on this option. It was under $100 bucks. Now, one review mentioned that when mounted the zipper for the awning faced up which could allow water into the case, I saw a YouTube video where the guy removed a couple screws, flipped the awning around in the track within the case and put the screws back on the clip and voila! No issues what so ever since I’ve had it.
  15. Sep 17, 2020 at 7:35 AM
    #995
    Ranger357
    Ranger357 Well-Known Member
    Ken
    Peoples Republic of Connecticut
    2018 TRD Off Road
    Bilstein 5100's OME 888's JBA UCA's Torch Off Road AAL Cavalry Mud Terrain 265-75-16
    Truck looks great
    Do you get any glare off of the white hood ?
    FreshPots[QUOTED] and Juniorbpd like this.
  16. Sep 17, 2020 at 10:00 AM
    #996
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Not as of yet but haven't had a chance to really play with it at night or aim it properly yet. Planning on doing that this weekend. If I get horrible glare I'll let you know lol
    Ranger357[QUOTED] likes this.
  17. Sep 17, 2020 at 10:15 AM
    #997
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Funny how these things are different. I took mine off and it sounded like I was driving through a tornado or something. Put it back on and quiet, relatively, again
  18. Sep 17, 2020 at 11:13 AM
    #998
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Huh, that's pretty strange. After I put my light bar up there it was even quieter. You'd think a large flat surface up there would make some noise but nope. Mine with the OEM fairing up there was horrendous. Like 20mph sounds like a wind tunnel style. Even with bulb seal.
  19. Sep 19, 2020 at 9:30 AM
    #999
    bttrbsch
    Michael
    Bellingham, WA
    Well, added the bulb seal and lowered the back to the lowest position, rack still makes a ton of noise. Not sure what to do next.. any more ideas?
  20. Sep 21, 2020 at 6:42 AM
    #1000
    zjcas
    zjcas Well-Known Member
    Zach
    Hooksett
    2012 DCSB TRD Sport
    Fox 2.0 COs, Fox 2.0 Resi's, Wheeler's Prog. AAL.
    In all honesty that may be about it. Every roof rack is going to make noise, especially with permanent cross bars. Some guys have taken the whole front fairing off and that cut down noise. If you want a project you can drop your liner and pull the carpet and roll in some sound deadening insulation but you'll have to turn up the radio and deal with it or ditch the rack imo.
    bttrbsch[QUOTED] likes this.
