Hooked up ********* 5 channel amp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trdpro85, Mar 30, 2019.
  1. Mar 30, 2019 at 3:06 PM
    Trdpro85
    Trdpro85 [OP] Well-Known Member
    2018 TRD PRO
    Hooked up the amp and now my backup camera, bluetooth, and steering wheel controls for the audio system are not working. I put it back to factory just to check everything and it still doesn't work. Is there a fuse or anything else I can check?
  2. Mar 30, 2019 at 3:08 PM
    tcjacado
    tcjacado Well-Known Member
    Fuses. Volt meter test the fuses.
  3. Mar 30, 2019 at 7:40 PM
    Trdpro85
    2018 TRD PRO
    Done that. Still no dice. The Bluetooth says Mic not connected.
  4. Mar 30, 2019 at 7:41 PM
    tcjacado
    So you have voltage everywhere then.... could be a ecu issue at this point.
