Hooking fogs up to headlight buzzer?
Discussion in 'Lighting' started by davidpick, May 2, 2011.
  1. May 2, 2011 at 7:57 PM
    davidpick
    davidpick [OP] NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    I've got my foglights all wired and set up and they work great. except for when i leave them on overnight (done this once a couple months ago and almost did it over the weekend! :( ).
    So what I want to do is to connect them to the buzzer/chime that sounds when i open the door and the headlights are on, reminding me to turn them off. I wired the fog lights essentially straight to the battery (in-line fuse of course) because i want to be able to use them with the truck off, if necessary, but this means i can accidentally leave them on.
    does anyone have any insight into how this could be accomplished? i have a wiring diagram for the truck, but i can't find the buzzer circuit anywhere!
    any help would be greatly appreciated! :)
  2. May 3, 2011 at 12:05 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    When adding lights to a circuit on my '04, I noticed that the buzzer/chime came from a little box under the fuses on the dash. (Shown on J/B no. 1 on diagram)
    That should be the physical location of the buzzer/chime.
    I think that you might be able to work out some sort of circuit wizardry using the key reminder. Perhaps add the light circuit to that somehow.
    I'm not much help, but this might be able to get the ball rolling for you
    Bottom of the page has electrical stuff for the 2000 model
  3. May 3, 2011 at 7:14 AM
    davidpick
    David
    Leavenworth, WA
    hey, thanks for the pdfs!
    it got me thinking it may be possible to add the fog light power feed to the power into the buzzer (bundle it with the headlights). the stock wiring after the buzzer should take care of the rest...
  4. May 3, 2011 at 7:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why not use a relay so they turn off when you turn the ignition off? No buzzers and no way to leave them on by accident.
  5. May 3, 2011 at 8:37 AM
    davidpick
    David
    Leavenworth, WA
    i may end up doing that, as i probably wouldn't want to leave them on when the truck was off for very long anyways and i can already use the headlights with the truck off as it is.
  6. May 9, 2011 at 6:09 PM
    davidpick
    David
    Leavenworth, WA
    so i ended up just dropping in a relay and tying it off the 9v accessory plug. decided it was easier.
