Hooking up ARB tire deflator kit inline with a compressor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Jul 5, 2019.
  1. Jul 5, 2019 at 9:04 AM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Probably a stupid question, buts it's tacomaworld...it's full of them.
    I've seen the ARB tire deflator kit but does that gauge allow you to hook it up inline with a compressor so I can see what the PSI is at as I refill my tires?
    Specifically: does the gauge allow me to deflate and inflate while seeing the PSI?
    GillyLink likes this.
  2. Jul 5, 2019 at 9:07 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
  3. Jul 5, 2019 at 9:11 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    You are looking to do the military style inflate/deflate from the cab, right?
    From what I have seen the ARB does not do this in the kit available on a mass scale.
    I would see about contacting ARB and inquiring if they could do a special kit or instruct you on how to make theirs work the way you want.
  4. Jul 5, 2019 at 9:13 AM
    Dr. Emmett Brown
    I'm just trying to use the psi gauge for both inflate and deflate readings but I'm thinking it's only good for deflating. Would have to get a separate gauge to attach to the end of my hose for pressure readings while inflating.
  5. Jul 5, 2019 at 9:14 AM
    Gixerkiller
    Dennis
    Taylor, TX
    Ahh, ok, makes sense now. Just get a quality one....
  6. Jul 5, 2019 at 9:15 AM
    Dr. Emmett Brown
    Will do. Appreciate the feedback.
    Aloha :hattip::cheers:
  7. Jul 5, 2019 at 9:28 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have one in the garage that I picked up about 6 months ago that allows me to inflate and deflate while giving instant readings but don't like it at all.
  8. Jul 5, 2019 at 9:32 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    TacoManOne likes this.
  9. Jul 5, 2019 at 9:34 AM
    Dr. Emmett Brown
    Would an inflator with gauge that has a pressure relief button work? Don't really care about how long it takes to air down
  10. Jul 5, 2019 at 9:38 AM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    tonered likes this.
  11. Jul 5, 2019 at 9:40 AM
    Dr. Emmett Brown
    I was looking at a similar product. But like I said the one I'm seeing has a button to release pressure which I think will work.
  12. Jul 5, 2019 at 9:40 AM
    OnHartung'sRoad
    No, if you don’t have it connected to a compressor it is just an open pipe.
  13. Jul 5, 2019 at 9:41 AM
    OdiN1701
    Colorado
    It should, although that's really only to release the internal pressure of the gauge and I bet that would be very painfully slow.
  14. Jul 5, 2019 at 9:42 AM
    Dr. Emmett Brown
    I think I see what you guys are saying. Damn.
    Looks like I'll just need a separate thing for inflate and deflate.
    Thanks
  15. Jul 5, 2019 at 9:43 AM
    OnHartung'sRoad
    Check out the auto deflator caps I
    Linked (but you can also find cheaper ones - ARB has them too).
  16. Jul 5, 2019 at 9:45 AM
    OdiN1701
    Colorado
  17. Jul 5, 2019 at 9:46 AM
    Dr. Emmett Brown
    60 bucks!?
  18. Jul 5, 2019 at 9:48 AM
    tcjacado
    tcjacado Well-Known Member
    60 percent mark up in all overlanding gear:D
  19. Jul 5, 2019 at 9:49 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Pressure does not work that way lol.
    Boyle's Law says P1V1=P2V2, where P=pressure and V=volume. One side is the compressor and the other side is the tire. Well, volume is different so the only way to satisfy the equation is with pressure. What this means one side has to have a higher pressure. If you had a gauge in the middle you would see a meaningless pressure as the tire was being inflated. Now, if you buy an inflator gauge, you have to stop inflating and then you can see the tire pressure.
    Further complicating things is the Ideal Gas Law of ((P1V1)/T1)=((P2V2)/T2) where T=temperature.
    Not a stupid question. Just requires the right answer. There's a reason "psi" in in my screen name. ;)
    Ensemble88 likes this.
  20. Jul 5, 2019 at 9:49 AM
    Dr. Emmett Brown
    Forreal ah!? Guess I'm part of that lifestyle now where we all spend money like we own it.
