Hooking up Head Unit to Dim
Discussion in 'Audio & Video' started by Warhorseforever, Jun 29, 2011.
  1. Jun 29, 2011 at 8:03 PM
    Warhorseforever
    Warhorseforever [OP] Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Hi I have a Kenwood Excelon KDC-X395 head unit in my 2001 Toyota Tacoma Pre-Runner SR5 3.4 V6 and I am trying to figure out how to wire in the head unit to dim at night when the lights are on. How would I do this? Would I splice into my dash light brightness knob the litttle twist knob that dim's the dash lights? Any help is appreciated.:)
  2. Jun 29, 2011 at 8:06 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Isn't the factory radio dimmable?
  3. Jun 29, 2011 at 8:09 PM
    Warhorseforever
    Will
    Sand Lapper
    I'm not sure I've got an after market but when I installed my adapters all the wires were accounted for and connected so I was trying to figure out where I needed to splice my dimmer wire coming out of my head unit.
  4. Jun 29, 2011 at 8:15 PM
    dexterdog
    Oly WA
    2012 F150
    There wasn't a dimmer wire on the harness adapter? Usually it's just matching color to color.
  5. Jun 29, 2011 at 8:28 PM
    Warhorseforever
    Will
    Sand Lapper
    There was one coming from the new hu but none matching from the adapter or harness.
  6. Jun 29, 2011 at 9:34 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If all else fails, theres a dimmer wire you can tap into from the shifter backlighting (assuming you have an automatic). I believe its green, pop the shifter cover off and you'll see everything comes apart pretty easy, just tap into it and run your wire. Its is controlled by your factory dimmer switch. I'm not exactly positive if it works, but its a dimmable circuit.
