Hoop or no Hoop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Jan 4, 2012.
Add a Hoop or leave it as is
Poll closed Feb 3, 2012.
  1. As is without hoop
    23 vote(s)
    26.4%
  2. add the hoop
    64 vote(s)
    73.6%
  1. Jan 4, 2012 at 3:08 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Should I add a center hoop to my bumper, what does everyone think.
    Bumper as it is right now:
  2. Jan 4, 2012 at 3:09 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    I vote for no hoop
  3. Jan 4, 2012 at 3:15 PM
    nhtundra
    nhtundra Well-Known Member
    NH
    2015 Dcab Sport Barcelona Red
    No hoop. Looks good the way it is.
  4. Jan 4, 2012 at 3:19 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Hoop. Better for animal strikes, better for wheeling.
  5. Jan 4, 2012 at 3:22 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Thats what I was thinking.
  6. Jan 4, 2012 at 3:26 PM
    jandrews
    One of the more enjoyable trail activities is to have a small tree down in front of you and just plow through the fucker or push it out of the way.
    No hoop = shit I just mangled my grille.
    Hoop = tree slides down the hoop to the bumper, no problem!
  7. Jan 4, 2012 at 3:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Jandozer
  8. Jan 4, 2012 at 3:40 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    No doubt
  9. Jan 4, 2012 at 4:07 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  10. Jan 4, 2012 at 4:38 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Hoop, and bring the sides of the bumper out a little more to match up with the fender flares. There's virtually no protection there right now. :eek:
  11. Jan 4, 2012 at 4:51 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I'm gonna say no hoop.
    I have yet to see a functional stinger on a 05+ Tacoma and IMO those aren't functional stingers. They just don't stick out far enough to make a difference and save your ass when the approach angles are horrible.
    No need IMO to put added weight up front but my grill and rad support is already FUBAR so take my opinion with a grain of salt if it's for animal impacts.
    I have zero issues slowly driving over small trees with no hoop...for that matter I had no issues driving over small trees when I had a avid bar.
    On the other hand if the hoop isn't just welded to the top and goes through the bumper and then is welded to the backside (like ARB) I could see it strengthening the bumper significantly.
  12. Jan 4, 2012 at 4:53 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Ill be welding wings on both sides to take care of that issue. I have both wings cut out already just have to remove the bumper to weld them on.
  13. Jan 4, 2012 at 4:55 PM
    XXXX
    sKiP
    05 Prius
    This looks stronger then no hoop
  14. Jan 4, 2012 at 4:57 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    :thumbsup:
    :drool:
  15. Jan 4, 2012 at 4:57 PM
    XXXX
    sKiP
    05 Prius
    Some guy on TTORA.
    The real question is why does he have less ground clearance then a stock Tacoma? lol
  16. Jan 4, 2012 at 4:58 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Hoop, otherwise you'll just mangle your grill when you run over a tree offroad.
  17. Jan 4, 2012 at 4:58 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Ah just noticed the drop bracket. :eek:
    The bumper and headlights, roof rack and wheels are sweet though!
  18. Jan 4, 2012 at 4:59 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    The hoop will be through the bumper and welded on top of the bumper and also on one of the main structural beams on the internal portion of the bumper
  19. Jan 4, 2012 at 5:07 PM
    XXXX
    sKiP
    05 Prius
    IDK what speed you guys are running trees over but I never had an issue crawling over them lol I'm not going to post any pictures cause trees are offtrail, but I never had an issue swerving around a swamp hole into the woods taking a few out and I can't even balance a beer on my bumper it's so shallow.
    Sounds good then. Hope to see it in person one day when your done.
  20. Jan 4, 2012 at 5:45 PM
    OZ-T
    Peter North
    British Columbia
    He's TW member Blacktaco21 too ;)
