*Hopefully* constructive discussion about the 3rd gen and it's issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by usedtothisnewness, Apr 6, 2017.
  1. Apr 17, 2017 at 5:58 AM
    #141
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Krucen 01, Taco16LB, Taco Fan and 2 others like this.
  2. Apr 17, 2017 at 6:18 AM
    #142
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    If you struggled to pass some one doing 50-55, then let me explain one very important thing, the skinny pedal on the right side is called the accelerator, if you press down on it it causes the truck to drink more fuel and accelerate faster. I have done it with mine a few times and can not tell you how fast it went, as I would be breaking the code of conduct here on this site. I will tell you this, it does have a point where the computers will not allow it to accelerate any more, and it's double what you say your truck struggle to reach.
  3. Apr 17, 2017 at 6:28 AM
    #143
    Duff49
    Duff49 Well-Known Member
    Bucks County PA
    17 Sport TRD DCLB Barcelona Red
    Sorry - I should have been descriptive.
    It's not the little pedal. I did learn how to do that 50 years ago. Unfortunately it's the trans again. Takes way too long to wake up. Or; Shifts to low, engine screams, and goes nowhere.
    And yes - I have slammed it to the floor several times out of frustration. Response was no faster.
  4. Apr 17, 2017 at 6:44 AM
    #144
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Did you read in pickup trucks dot com reports how bad the ridge sags with that spec payload and how unpredictable the brakes are with it ? Didnt think so. Taco doesn't need to stretch the data in sales brochures. Ridge doesn't win shinola, it's a napoleanic car.
    Krucen 01 and TheCookieMonster like this.
  5. Apr 17, 2017 at 7:22 AM
    #145
    moderman
    moderman Well-Known Member
    For sure sell your truck, obviously unhappy.
    Looked back at your post history, all negative about drivetrain. Just trade it and take a loss. No one is going to believe you don't have enough power to pass ppl on highway, because that makes no sense.
    Might be under powered for some, but it will go more than 55 and it is certainly not unsafe.
    Can't imagine toyota is going to tell you anything, they probably think you are nuts!!
  6. Apr 17, 2017 at 7:25 AM
    #146
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Maybe it was an F-150 ecoboost
  7. Apr 17, 2017 at 7:26 AM
    #147
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Have never, not once, experienced that. When I need to stomp it and pass
    it has never had an issue with it.
  8. Apr 17, 2017 at 7:31 AM
    #148
    2016Tacoman
    J
    Agreed. If you are at 55 and hit it you are put back in the seat with close to 300 hp. It doesnt play around at those higher rpms, period. Look at the charts. These people that post otherwise are trolls that don't have one.
  9. Apr 17, 2017 at 7:35 AM
    #149
    2016Tacoman
    J
    But you said you fixed your howling diff last week with the lift as it was a driveline angle issue. So it's not failing diffs.
    TheCookieMonster likes this.
  10. Apr 17, 2017 at 8:37 AM
    #150
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    He never said he fixed the Howling, l just thought he said the volume of the Howling is lessened.
    smitty99 likes this.
  11. Apr 17, 2017 at 8:40 AM
    #151
    smitty99
    Scottsdale
    Holy shit people love to twist words, don't they? This guy...there's a reason I have him on ignore.
    You're correct Shaker, there's still a slight howling noise. It is less noticeable since I added the mild lift. I DO NOT deem this as a solution at all and in fact my service manager advised me to keep the lift very mild so that my case (well-documented with Toyota) would still be handled if/when the official solution is fielded.
    At first I thought it went away but then a few days later I noticed it very lightly on the highway again. I updated the fact this didn't solve the issue on 4/13 here https://www.tacomaworld.com/threads...ft-bilstein-5100s.483874/page-3#post-14907574 as well as in the Diff howl Poll thread
  12. Apr 17, 2017 at 9:47 AM
    #152
    2016Tacoman
    J
    "Interestingly enough I also cannot hear any diff whine now that the rear end is lifted slightly. I feel like this further supports theories of driveline angle playing a role."
    Search it. It's his post. Twist words ? it's your quote !
    https://www.tacomaworld.com/threads...ft-bilstein-5100s.483874/page-2#post-14891688
  13. Apr 17, 2017 at 1:02 PM
    #153
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Very cool. You learn something everyday here on TW. Thanks!
  14. Apr 17, 2017 at 5:16 PM
    #154
    Duff49
    Bucks County PA
    I guess you must have misunderstood my previous post -
    And yes - I have slammed it to the floor several times out of frustration. Response(the motor bogging down) was no faster.
    As others have explained - another issue is the motor and trans working together. My previous post explained that when passing, the trans downshifted too low and the engine revved up to 5k near redline and would not rev higher. At the same time the trans never shifted up. So it went no faster. The trans never shifted up until I let off the "Little Pedal" .
    I agree; When it downshifts correctly, it does pin you back. But; When you go to pass on the highway or in street traffic, two to three seconds of bog down is unsafe.
  15. Apr 17, 2017 at 5:20 PM
    #155
    12 TRD OffRoad
    12 TRD OffRoad Well-Known Member
    Robert
    South Carolina
    2018 Tacoma SR 4x4 utility package
    It's amazing how my 5 speed in my 2012 is perfect and yet the managed to screw up the 6 speed so bad. Toyota must have a former Dodge employee heading up the transmission department, Dodge knows they can't make a transmission to save their life.
    CJREX likes this.
  16. Apr 17, 2017 at 5:21 PM
    #156
    Spare Parts
    Southern Maine
    Some where in TW someone had a suggestion they said helped them start to enjoy driving the truck, the started rolling into the throttle and jumping on it. I was supprised to read this as I thought that's how every one should drive every vehicle. But I have driving manual trans for the last 20 plus years, and the only time I stomp it is when I am trying to geT some noise out of the tires or make the engine scream.
    boynoyce likes this.
  17. Apr 17, 2017 at 5:28 PM
    #157
    su.b.rat
    su.b.rat broken truck
    all the armchair arguing types who jump on my pedal commander props always say that stomping on it is the same thing. who over 25 drives like that? well, except for that one guy.. :p
  18. Apr 17, 2017 at 5:29 PM
    #158
    Spare Parts
    Southern Maine
    S
    so, exactly what is this pedal commander and what/how does it work?
  19. Apr 17, 2017 at 5:33 PM
    #159
    su.b.rat
    tell me you're not actually asking me that.. [​IMG]
  20. Apr 17, 2017 at 5:35 PM
    #160
    Spare Parts
    Southern Maine
    I am, from what I understand it's another computer between you and your truck.
