Hopefully this helps someone- rearview mirror adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Veevee, Aug 18, 2024.
  1. Aug 18, 2024 at 9:28 AM
    Veevee
    Veevee [OP] Member
    2022 ORLB
    Well, the rearview mirror on my new 22 OR hangs pretty low, blocking my view out of the right side of the front window. I did some research and found that the neck of the mirror is adjustable. I went out to the truck and gave it a little push upwards to test this out and sure enough, it's true- great news! So I pushed it up, kept going and thought, why not go all the way. Right at the end I heard a little pop, so I stopped.
    Took me a couple seconds to realize I had cracked the front windshield! Unbelievable. What was at first some very good news, turned south just like that. It now has two 10" cracks leading out from the mirrow mount location.
    I hope this helps some folks in that yes you can adjust the neck of your rearview, but also, be careful.
    I'm assuming it's safe to drive until I can get it fixed in a few days? Anyone have thoughts on that?
    Also, what's a reasonable price to pay. I know it can vary a bit, but what's the average?
    Have a good day !
    Tocamo likes this.
  2. Aug 18, 2024 at 11:34 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Picture needed to make a judgement. Without a picture the only thought I can offer is that if the cracks have reached the top edge of the windshield the risk is greater than if the cracks are still inside the edges. But in the end that advice is might be worth exactly how much it cost you ... nothing.
    Good luck.
  3. Aug 18, 2024 at 12:53 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sorry this happened to you OP. But I'm surprised that Toyota would include a design flaw in this feature that would allow you to break the windshield?
  4. Aug 18, 2024 at 3:07 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Bummer of a first post! Welcome to the forum though.
  5. Aug 18, 2024 at 4:40 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Sorry that happened to you. I've done the mirror up/down many times without a problem, I know no help to you.
