hopping for some help
Discussion in '1st Gen. Tacomas (1995-2004)' started by sspecht35, Aug 2, 2015.
  1. Aug 2, 2015 at 1:09 PM
    sspecht35
    sspecht35 [OP] New Member
    so the check engine light came on and i took it to a mechanic.... they said the light was indicating the vacuum system, and ran a smoke test to see if there were any leaks. The mechanic couldn't find anything that would have set off the check engine light so he turned off the light and said it was fine. Driving on the highway as the truck shifted in to passing gear the light came back on. Does anyone know what this problem could be ? I need to get it fixed so i can emission the truck and drive it again ...... 2000 tacoma 6cyl 4wheel drive
    thanks
  2. Aug 2, 2015 at 1:28 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Buy a new gas cap.
  3. Aug 2, 2015 at 6:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Be nice to know just what code it was tripped
