Horale
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoslocos4ever, Sep 29, 2015.
  1. Oct 2, 2015 at 12:23 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not surprising the 2 + 1 packs are known to be horrible. An AAL would be a poor Band-Aid at best. I encourage everyone with a 2 leaf to get a complete new pack.
  2. Oct 2, 2015 at 1:57 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    My pack (and truck) was brand new, so not really a poor bandaid, but thanks.
    I had no issues even hauling 1100 lbs in the bed, I wasn't on bump stops or hitting them. Only complaint with that setup was it didn't have the height I wanted. I could lower my front end or I could raise the rear. I opted to redo both front and rear suspension instead.
  3. Oct 2, 2015 at 1:59 PM
    T4RFTMFW
    Your 4 leaf is only a minor improvement. If you think the band aid of 3 leaf AALs only apply to the 3 leaf packs, that's fine. But you'll understand one day.
  4. Oct 2, 2015 at 2:22 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thats why I replaced it all with a new leaf pack as well..
  5. Oct 2, 2015 at 2:27 PM
    tacoslocos4ever
    tacoslocos4ever [OP] Well-Known Member
    tom
    2015 TRD Off Road
    My thread is blowing up! I feel important.
    All this back-and-forth has me leaning towards Dakars with the third leaf removed, which I've been reading will net me about 2.125" of lift in back. I think that'll work with the 2.5" in front I'm shooting for.
    Adios taquitos.
  6. Oct 2, 2015 at 2:33 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I'm trying to get around 1.5" over stock AND improve cargo performance. My 2013 has the 3+1 factory springs. Because it's a Baja it sits level when unloaded. I have an Extang Solid Fold cover on it that weighs maybe 75 pounds. Any additional weight and it sags past level. I put 20 bags of wet mulch in it this summer and it hit the stops over small bumps. I think that anything more than 1.5" or so would look to high in the back compared to the Baja 1.5-ish factory front lift. The problem is that all of the full spring packs are rated at 2" or more, and most people say that they end up higher than the rating.
  7. Oct 2, 2015 at 2:37 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    are you trying to level? if so, you will be ass high with that setup.
  8. Oct 2, 2015 at 2:39 PM
    PaulK
    Paul
    Pittsburgh, PA
    No, I'm okay with a little higher in the back. It's level now, but 1.5" is fine with me. I just don't want it TOO high.
  9. Oct 2, 2015 at 2:51 PM
    tacoslocos4ever
    tom
    2015 TRD Off Road
    If I go up 2.5" in front and 2.125" in back, I will still have rake but less than factory. I'm ok with that.
  10. Oct 2, 2015 at 2:56 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    alrighty.
  11. Nov 24, 2015 at 3:14 PM
    DesertSand
    DesertSand Well-Known Member
    San Pedro, CA
    2013 DCSB Nautical Blue
    OP, did you pick a pack? I'm looking at finding a pack that nets around 1.5" as well since I have the standard King rear shocks.
