Horn beeps at unlock/lock
Discussion in 'New Members' started by ccarrillo, May 7, 2017.
  1. Aug 24, 2017 at 10:29 PM
    tcjacado
    tcjacado Well-Known Member
    It may be an option within the trucks software to disable the feature in question. Tech stream is the software interface and the obdll is the hardware
  2. Aug 25, 2017 at 5:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    Is it your actual horn that goes off?
    tcjacado likes this.
  3. Aug 25, 2017 at 6:58 AM
    tcjacado
    Yes the horn sounds when push the lock or unlock button on the key chain remote, key fob, like mine that has key with the lock/unlock pads on the key.
  4. Aug 25, 2017 at 7:17 AM
    2010tacoma2tr
    2010tacoma2tr Well-Known Member
    Have you tried both with waiting 10 seconds and not waiting 10 seconds? Seems to me there are only 2 ways to interpret that, and by trying both ways you would be able to confirm.
    I did this a few months back with success. I believe I waited the 10 seconds.
  5. Aug 25, 2017 at 7:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Do you have a valet button?
    It sounds like there is an alarm installed on your vehicle. Toyota doesn't utilize the horn unless they install an aftermarket alarm.
    tcjacado[QUOTED] likes this.
  6. Aug 25, 2017 at 7:32 AM
    2010tacoma2tr
    I dont think that's accurate. My horn used to beep with locking/unlocking, and there is no aftermarket alarm on it. Just what came from the factory.
  7. Aug 25, 2017 at 7:35 AM
    tcjacado
    No I do not in my truck. I do not have a issue with it. I was only trying to help a unanswered post on the matter.
  8. Aug 25, 2017 at 10:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    It may have an alarm form the factory then. Do you have the window tag from your original purchase?
  9. Aug 25, 2017 at 11:13 AM
    2010tacoma2tr
    No, Im the second owner..but the posted process did work for me. I can lock and unlock without the horn sound now.
  10. Aug 25, 2017 at 1:22 PM
    Tacoma HEART
    Tacoma HEART - - - - - - -
    Sam
    AA CO
    '14 DCSB TRD S Black
    Yawn...
    I'm gonna try this as soon as I get off work.
    Did you count 10 seconds while you clicked the lock/unlock button twice, or did you count 10 seconds AND THEN click the lock/unlock button?
  11. Aug 25, 2017 at 1:29 PM
    Tacoma HEART
    Sam
    AA CO
    Yawn...
    I do have the Viper smartstart system, so while I do have the option of a silent lock/unlock: the process is quite lengthy and dependent on the system to receive the signal in the first place. (As our Tacomas require an unlock function twice to open a passenger side).
    Just in case anyone is wondering how to go about this with a Viper fob: f key, unlock key (or lock).
    4 buttons in succession to open a passenger door in silence = I need this to work!! Don't tease me!
  12. Aug 25, 2017 at 1:32 PM
    2010tacoma2tr
    I counted to 10 AND THEN clicked the fob twice
    Step one: Open the drivers door and insert the key into the ignition
    step two: Remove the key from the ignition and, within 5 seconds,
    reinsert the key back into the ignition and switch to the on position.
    Within 10 seconds, the system enters the answer-back mode
    step four: Count to 10 after switching the key to ON and then press the remote twice and you should hear a long beep. This should turn off the horn feature
    https://www.tacomaworld.com/threads/door-lock-unlock-beep-how-to-turn-beep-off.60137/
    Tacoma HEART[QUOTED] likes this.
  13. Oct 16, 2018 at 2:02 PM
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    2013 Tacoma AC 4x4 M/T 2.7L
    @TheLRZ, any luck with disabling your horn from honking during lock/unlock with a remote? I'm asking 'cause I have a 2013, as well.
  14. Oct 16, 2018 at 2:07 PM
    smw62891
    smw62891 Well-Known Member
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    This procedure worked
    For me! Only took a couple of times and had to have my door open.
  15. Oct 16, 2018 at 2:16 PM
    #35
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    Just want to make sure, is this for the beep or the honk? 'Cause I tried this method and it only affected the beep on mine.
  16. Oct 16, 2018 at 3:27 PM
    #36
    smw62891
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    Ahh I didn't read close enough, was only the beep on mine. I don't have the horn go off with my 09.
    SOUPBOY[QUOTED] likes this.
  17. Feb 3, 2021 at 7:06 PM
    #37
    Daniel-Slagle23
    Daniel-Slagle23 New Member
    Daniel slagle
    06’ access cab Tacoma
    I have an 06 Tacoma but my dad took the horn confirmation out when he first got it but I would like it back in how would I get it back?
  18. Feb 3, 2021 at 7:15 PM
    #38
    Brabyn Ranch
    Brabyn Ranch Active Member
    Sorrento BC Canada
    2017 Tacoma TRD Sport DCLB
    LED Headlights
    I took my 2017 into the dealer and they said it couldn’t be done - no horn on lock - there is only a buzz sound
  19. Feb 5, 2021 at 4:57 AM
    #39
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  20. Feb 5, 2021 at 5:08 AM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    Thread started in 2017, ended in '18. Some participants have not been around since.
    Recommend starting with your owners manual. If you don't have it, it can be found in PDF form on Toyota's website.
    https://www.toyota.com/owners/resources/warranty-owners-manuals/tacoma/2006
    If you still need help, a new thread in the 2nd gen forum would be next.
