Horn burns fuse.
Discussion in 'Toyota Trucks & SUVs' started by aaronfe, Aug 14, 2014.
  1. Aug 14, 2014 at 7:31 AM
    aaronfe
    aaronfe [OP] New Member
    Aaron
    Louisiana
    2000 Toyota Tacoma
    I have a 2000 Toyota Tacoma that burns a fuse everytime I push the horn. This fuse is shared with the flashers so naturally they go out too. After going through 4 fuses I have determined that the flashers will operate just fine as long as I leave the horn alone. My guess is that the horn is the culprit but I'm not sure if this is a grounding problem or where to start. The truck was purchased 2 years ago as a totalled/reconstructed just for additional information. I am open to any advice on where to start or ideas regarding what could be wrong.
  2. Aug 15, 2014 at 3:05 PM
    09dcsb
    09dcsb Well-Known Member
    uvalde,tx
    09 dcsb
    maine truck rack, huskyliners, bhlm, marathon seat covers, camo ventvisors, k&n filter, lift and tires coming soon to a Tacoma near me
    unplug the horn and hit the button. if it blows the fuse then the problem is in the harness or switch. if the fuse is still good then replace the horn
  3. Aug 15, 2014 at 3:38 PM
    aaronfe
    Aaron
    Louisiana
    2000 Toyota Tacoma
    Thank you for your response. I found the horn and upon disconnecting it realized that the connections are pretty corroded. With some cleaning I reconnected the horn. Sure enough it worked. Thrilled I can honk like the rest of these Louisiana drivers.
