Horn, cruise control, airbag light... Same time
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texasdynaryder, Nov 9, 2011.
  1. Nov 9, 2011 at 8:26 AM
    Texasdynaryder
    Texasdynaryder [OP] Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Still learning how to work on the taco... but have zero knowledge on internal steering components... But my horn and cruise non longer work.. Fuses are good. And also the air bag light is on. Easy fix? :playball:
  2. Nov 9, 2011 at 8:28 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yikes, are you sure the fuses are all alright? I had one go out and it caused some strange symptons that I wouldn't have thought related..
    Good luck!
  3. Nov 9, 2011 at 8:32 AM
    Texasdynaryder
    Chance
    Paris, Tx
    all of them are good. Had a buddy tell me it maybe have to do with the steering.can do serious engine work but im very incompetent when it comes to wiring lol
  4. Nov 9, 2011 at 9:56 AM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    I had the same issue afte I replaced my rack and pinion. Turns out that when I reinstalled everything something got out of wack and I broke the spiral cable aka clock spring in my steering wheel. It controls the air bag, horn and cruise ect. In the steering console. You might have the same issue.
  5. Nov 9, 2011 at 9:57 AM
    Gorillazrus
    01 Prerunner SR5
  6. Nov 9, 2011 at 10:02 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  7. Nov 9, 2011 at 10:35 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Ah ha clock springs it is guys... Thanks...
  8. Nov 9, 2011 at 12:42 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    Broken clock spring.would be my guess. had the same thing happen on mine after the steering wheel was turned while I had the linkage disconnected.
