horn dont work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, Mar 31, 2010.
  1. Mar 31, 2010 at 11:01 AM
    bluebeast
    bluebeast [OP] Active Member
    06 bluebeast
    smitty bulls bar procomp 3in lift westin nerf bars
    i was trying to mount my horn in a different area. first i cut the wire that was connected to the tab that is input into the horn. i then use a long wire to connect what i cut so i can mount the the horn close to the firewall. the first horn work but when i try to do the second horn there was to wire so i thought that i can just connect the two wires to the first horn. NO NO NO. now both of my horn does not work. the fuse is still good not blown. please help
  2. Mar 31, 2010 at 11:07 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    subbed. my second horn stopped working after i moved it also but my wires are still connected. hopefully someone has some ideas
  3. Mar 31, 2010 at 11:11 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Mar 31, 2010 at 11:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The horn grounds itself through the mounting tab (see above picture). Check to make sure you have good contact between the tab, the frame, and the horn.
  5. Mar 31, 2010 at 11:15 AM
    CopDoctor
    08 335i
    i realize the error in my ways....i'm foolish lol. bluebest if you remount and reconnect like it was before are they still not working?
  6. Mar 31, 2010 at 11:17 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Horn doesn't work :D
    Maybe a ground?
  7. Mar 31, 2010 at 12:22 PM
    bluebeast
    06 bluebeast
    thanks guy got it working again. it was wired. i left it alone for 10 mins. came back and it work. WIERD. but all is good. thanks guys
  8. Apr 1, 2010 at 3:19 AM
    MyMistress
    MyMistress Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
    I dont think I've ever pushed mine... Better go check it!
  9. Apr 1, 2010 at 3:27 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    :brianr:thats what i use instead :D
