horn goes off when i turn head lights on
Discussion in '1st Gen. Tacomas (1995-2004)' started by mfkokoska, Jan 27, 2014.
  1. Jan 27, 2014 at 3:25 PM
    mfkokoska
    mfkokoska [OP] Active Member
    matt
    sydney ns canada
    hey guys i have an 2003 tacoma . i"ve been having an issue with my horn for the last week. when i turn my headlights on the horn randomly goes off. this is pretty shitty because now i can't dive at night. any help would be appreciated thanks
  2. Jan 27, 2014 at 5:57 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Do you have an aftermarket alarm system by chance? Just a thought, maybe the alarm box is having issues and triggering the horn.
  3. Jan 27, 2014 at 6:01 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try a new (or different-from auto wrecker) headlight switch.
  4. Jan 27, 2014 at 6:09 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The horn and HL switches are close together, and therefore the wires. Maybe the have been rubbing over the years, and are shorting to one another. You'll have to take apart the steering wheel to get to it, though. Long shot.
  5. Mar 5, 2015 at 8:39 AM
    jotaco13
    jotaco13 New Member
    03 Tacoma
    I'm having the same problem. What was the result of this issue?
  6. Mar 5, 2015 at 9:01 AM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    do what tan4x4 said. it's not hard, just watch out for the air bag and keep track of the screws.
  7. Mar 5, 2015 at 11:51 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    my first thought is before you go digging into the dash wiring, look at the wires under the hood for a short, trace them back from the horn and lights to where it goes into the firewall.
    its a lot more likely that's where it will be if they are touching.
  8. Mar 5, 2015 at 11:59 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Sounds like a poor ground somewhere.
  9. Mar 5, 2015 at 1:20 PM
    Broke Okie Ty
    Ty
    I don't think so. When the lights are on there's power. The horn randomly goes off when the lights have power. That tells me the 2 wires have been exposed and touching together. The column is easy to take the shrouds off and see what can be found. Then trace them from the column to where ever they go.
  10. Mar 5, 2015 at 2:00 PM
    rzgkane
    You'd be surprised at the crazy shit that poor grounds cause. Seemingly unrelated systems interact with each other in ways that only an exorcist could explain. Trust me.
  11. Mar 5, 2015 at 2:21 PM
    Broke Okie Ty
    Ty
    I'm not saying they don't. I am saying start in at the column (end point) and work backwards checking the wires and grounds. It's a process of elimination that won't seem so overwhelming.
  12. Mar 5, 2015 at 2:34 PM
    keakar
    karl
    louisiana
    well while that is sound advice, the most common place for wires to be frayed, pinched, shorted, or damaged is under the hood which is why I prefer to tell people to start at the source and work your way back to the wiring harness and switches with the only exception is confirm the switch tests ok first.
  13. Mar 5, 2015 at 2:39 PM
    rzgkane
    My advice is to check all easily accessible grounds first. I've seen far more electrical problems result from poor grounds than I have two wires chafed and shorting to each other.
  14. Mar 5, 2015 at 2:43 PM
    Broke Okie Ty
    Ty
    AGAIN, I am not arguing that. The point I am making, is that if a person has to ask, THAT person would more than likely be overwhelmed by popping the hood and going at it.
  15. Mar 5, 2015 at 4:23 PM
    keakar
    karl
    louisiana
    yet you recommended he start by pulling the air bag and going in to the dash wiring first?????
    I wouldn't even suggest good mechanics do that unless they have some electrical training so they don't damage things pulling on wires, that's why I was confused by the suggestion to start by going into the dashboard without knowing if the guy has a clue about electricity or electrical troubleshooting.
    even a noob can spot a pinched or skinned wire under the hood where its easy to access and see things but I wouldn't suggest anyone go anywhere near digging into the dash wiring unless they have the training to do it correctly.
  16. Mar 6, 2015 at 11:13 AM
    Broke Okie Ty
    Ty
    A. The air bag is easy, 4 screws and a plug, to ensure it doesn't go off while working on it.
    B. One doesn't have to take the the dash apart. Pulling the column shrouds and dash shrouds should give enough room to see under the dash to examine wires.
    C. The best advice I can give someone who wants to try and work on their truck with out any "training" is, find a starting point, sack up, and do it. Otherwise, take it to a mechanic and pay through the nose.
  17. Mar 6, 2015 at 12:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would first check the horn relay under the hood. They are cheap. There may be the same relay in another slot that matches the horn relay. Swap them out and see what happens.
  18. Mar 6, 2015 at 12:38 PM
    keakar
    karl
    louisiana
    I understand your recommendation better now
  19. Apr 26, 2016 at 10:30 AM
    Sunset Cliffs
    Sunset Cliffs Member
    2001 Toyota Tacoma 2.7 4x4
    Did you get it fixed
