horn help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by Breakfast Taco, Jul 22, 2017.
  1. Jul 22, 2017 at 8:58 PM
    Breakfast Taco
    Breakfast Taco [OP] Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    I have no working horn on my 2002 Tacoma base 4WD. I was able to remove the center horn in front of the radiator - tests dead. BUT, there's no wires to the 2nd horn (behind the passenger headlight). Yes, there was a lite accident involving the front right corner. Before I pull the grill & headlights, & parking lights, & .....
    Can anyone tell me where the wires come from that connect to the horn that is behind the passenger (LHD) headlamp? I've followed the wire harness by touch & feel no signs of a trapped wire. The radiator horn, the wire just drops straight down from the harness to the bottom of the horn, but no similar is obvious to the horn behind the headlight w/o disassembling it all.
    Thanks for any shared experience.
  2. Jul 23, 2017 at 3:01 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Interesting I have no Horn behind the right head light .
    I have one to the left of the right head light on the radiator support.
    The wires come up from the bottom left
    17 year old truck I have no idea what might have been changed
    For what it is worth my EWD only shows one horn
    Then I have a 2000 with a 3.4
    Things must have changed
  3. Jul 23, 2017 at 3:09 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    In emergency use finger :oops:
  4. Jul 25, 2017 at 6:25 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    bump
    "Can anyone tell me where the wires come from that connect to the horn that is behind the passenger (LHD) headlamp? I've followed the wire harness by touch & feel no signs of a trapped wire. The radiator horn, the wire just drops straight down from the harness to the bottom of the horn, but no similar is obvious to the horn behind the headlight w/o disassembling it all."
    Maybe there's supposed to be a jumper from horn to horn, they're wired in series?
    Maybe the wiring comes up below, from somewhere down around the low signal lamp? (Doesn't make sense, but...)
    Buhler?...., Buhler?
  5. Jul 25, 2017 at 6:54 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  6. Jul 25, 2017 at 7:06 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can't remember what year Toyota went to 2 horns. My 98 only had 1, my 04 has 2.
    Wires to both horns drop down from the harness on the left side of the core support.
  7. Jul 25, 2017 at 7:32 AM
    Madjik_Man
    Colorado Front Range
    Dual horns started with the 01-04
    There is a jumper wire between the horns. Harness plugs into one and then there's one wire that goes to the second horn.
    When I upgraded to the 01-04 horn, all I had to do was run that one wire to the second horn.
    Dalandser likes this.
  8. Jul 25, 2017 at 12:54 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    EWD for 2003 shows that - a black wire between two horns. BTW, they are wired in parallel not in series. I did upgrade horn to my 95, which had a "beep beep" moped type single horn. Because I put hons behind front bumper (one on each side) I had to do mo wires, but the concept is the same. 15A fuse handles dual horn well.
    Original horn wire (black) and ground extended to power new horns in new locations
    Driver side horn
    Pass side horn:
    I have replaced these junk HF cheapo horns (they rusted through in 3 years) with FIAMM set and so far the are holding up.
  9. Jul 25, 2017 at 8:35 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    This makes sense to me, now I know what to do.
    Hate having no horn after someone almost broadsided me the other day where I learned I had no horn! Fortunately my reflexes were quick.
    Thanks everyone for the help!
  10. Jul 26, 2017 at 2:08 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Aha you guys gotta step up your game. I'm running four 1980's Cadillac DeVille 4 note horns in my truck along the stock Tacoma horn for a total of 5 horns. I mourned it in the valence under the grille.
    I originally hooked it up to the stock horn circuit but these drew so much power it kept burning out the breaker. I had to run a separate relay to handle the high amperage.
    I cut off the Cadillac mounting bracket and welded the horns to a flat stock of steel and painted it black. It grounds to the frame so it just needs the positive wire connections.
    Breakfast Taco[OP] and koditten like this.
  11. Sep 3, 2017 at 8:50 AM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    Update. My horn wasn't working because the clock spring was bad. Replaced that & now I have one horn. Need to run a wire to the second horn - it's just flat MIA. The truck had an accident in the past in the front right corner, I guess that wire was a casualty of the accident although I see absolutely no sign of it at all. Odd.
