Horn Honks 3 times with locking doors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueSteel, Dec 31, 2011.
  1. Dec 31, 2011 at 9:39 AM
    BlueSteel
    BlueSteel [OP] Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    Just like the title says. I had to pull my positive (+) cable from my battery to replace the terminals with some aftermarkets and I think that the keyless entry resetted back to some weird horn setting instead of just the beep beep alert. I get the beep beep honk honk honk (short bursts) when locking the doors now. Any Ideas? My neighbors are giving me evil looks because I replaced the factory horn with the compact Bad Boy Air Horn and it is loud at night with those honks.
  2. Dec 31, 2011 at 9:46 AM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    When I finished the install for my sound system I got the same problem when I reconnected the battery.
    However, at the same time, my rear passenger door lock got damaged, it does not open/close electrically and that seems to be the culprit.
    I would check to see if all your doors are closing/opening with the beeper.
    Side note: I still have not fixed it and my neighbors will probably give me evil looks soon as even I hate how loud it is.
  3. Jan 26, 2012 at 7:06 AM
    BlueSteel
    James
    The Woodlands, TX
    It turned out that my factory battery was going bad and Toyota recommended that it be replaced. I went ahead and purchased the Odyssey 34R-1500 Red Top battery. The horn does not do the honk anymore when I lock the doors with the remote, but the door locks won't engage/disengage anymore when I shift into park or drive like before. I can live without that feature though. Here are some pics of the difference in size. I had to cut a piece of oak for the factory mount because of the height difference.
    The wood piece is LWH 6 15/16" x 3" x 1" if anyone wants to do this. I liked this idea rather than go with a plastic tray to raise it up. The factory battery cables do not give a whole lot of slack to run aftermarket terminals. I originally didn't have a problem with the Ground (-) cable and a new terminal, but the Positive(+) had no slack so this works.
  4. Jan 26, 2012 at 7:11 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    FYI.....Odyssey has a mounting plate that you put under the battery to raise it to stock height.
  5. Jan 26, 2012 at 7:19 AM
    BlueSteel
    James
    The Woodlands, TX
    Yeah I originally saw that when I purchased it but I opted not to get it because of the factory cable lengths and wanting to go with new terminals. I like the low profile now. This battery has great output and even blew away the Toyota top-of-the-line True Start. I have owned an Odyssey Battery in the Past with my Jeep and that thing took every accessory that I threw at it, it was a true workhorse. :)
  6. Jan 26, 2012 at 7:22 AM
    BlueSteel
    James
    The Woodlands, TX
    Yeah I saw that when I purchased the battery but I wanted the lower profile to try and fit new terminals without having to lengthen the factory cables.
