Horn no longer works
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Amanwithnoplan, Dec 11, 2021.
  1. Dec 11, 2021 at 9:35 PM
    Amanwithnoplan
    Amanwithnoplan [OP] Member
    Sievrrhyn
    2015 Black Tacoma TRD Pro
    I noticed around Thanksgiving that the horn on my 2015 no longer works after someone almost hit me on the freeway. I have looked into the issue and my guess is a bad clock spring. Is replacing a clock spring terribly difficult? I have only ever changed oil and breaks, never anything else.
  2. Dec 11, 2021 at 9:41 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    It is pretty straight forward. I had mine replaced in about the same amount of time it takes to change the oil. I found a YouTube video that covered the repair.
    Easy way to confirm is to see if the horn beeps when you press the panic button with the keyfob. If it does, follow the video linked in this post for troubleshooting: https://www.tacomaworld.com/threads/horn-not-working.731618/#post-26061733
  3. Dec 11, 2021 at 10:23 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Have you checked the fuse and the relay for the horn? I would do that before replacing the clock spring if you haven’t already.
  4. Dec 13, 2021 at 3:52 AM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    Very easy to replace the clock spring.
    You can short the relay in the fuse box under the hood, if it honk it's not the horn, after that you can do a continuity test from the relay to the steering, open the little door with the screw under the lever for the turn signal on your steering and you will see a black wire plugged with a tab in the middle. Take some long nose and tap your alligator clip and see the resistance. If it's under 1 ohm from the relay to the steering the problem is 99.999% the clock spring.
    Torque for the steering nut is 37 lb/ft if i remember right. Don't forget to mark the center it's easy to misalign the steering wheel.
    this dude know is shit https://youtu.be/VblczY9PzMc
    I did mine 2 month ago with a cheap Amazon clockspring @ 45$ cad shipped. Still work, took 30 minutes
    PS: If you go with the cheap clock spring, check every connector pin in the housing, if one is missaligned, you will bend it and it's no go, the connector under take some force to remove and to reconnect, take it easy and bring a mirror or your cellphone to see how thing are placed when you remove/replace each part.
    Marc70 likes this.
  5. Dec 13, 2021 at 4:47 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
