Horn not working after changing intermediate shaft.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by M192, Nov 11, 2015.
  1. Nov 11, 2015 at 6:47 PM
    M192
    M192 [OP] Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    What the hell. After 4 hrs of fighting I got my steering shaft replaced Sunday. The lower one by the steering box. I didn't tie the steering wheel when I did it so when I pulled the coupler off the shaft the steering wheel must've spun around 5-6 times. Got it all back together and other than the wheel no being straight :facepalm: my horn dosnt work at all. Any ideas? Clock spring? Everything else works. Need to get the truck inspected before the end of the month and that's something they check. Gotta do my brake pads and fix my wheel before then hopefully.
  2. Nov 11, 2015 at 8:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes, The old clock spring cable has probably been broken. That is where I would bet my money.
    Did you get a fault for the Airbag... That also goes through the clock spring cable.
    Either way...
    landphil likes this.
  3. Nov 12, 2015 at 4:00 AM
    M192
    Dan
    Cambria county PA
    Alot
    Nope no problem with airbag. Damit that dam thing is expensive.
  4. Nov 15, 2015 at 12:26 PM
    M192
    Dan
    Cambria county PA
    Alot
    Nope. Found out that the plugs in the horn are just corroded.
