Horn not working but alarm works
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigZ31, Mar 28, 2025.
  1. Mar 28, 2025 at 12:14 PM
    BigZ31
    BigZ31 [OP] New Member
    Matthew
    2011 Tacoma 4x4 v6
    Hi yall, first post.
    looking to track down horn issue. Horn does not work when pressed but I can set off the alarm with key fob. Relay and fuse has been swapped and still has no effect. I’ve looked into clock spring but my blinker/cruise control/ buttons on steering wheel work so not convinced it’s the clock spring yet. What should I check next?
    thanks in advance.
  2. Mar 28, 2025 at 12:19 PM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    Sounds like a clock spring. When mine failed the horn stopped working but the controls on the wheel still worked. If you can hear the horn by using the keyfob that means the horn is still working (fuse and horn connector/ground would be the next step if you could not set it off). I would look into the clock spring steps. It's not overly complicated, just make sure the 12v system is disconnected and any power in the system drained before you disconnect the airbag. You can get a loaner steering wheel puller from Napa/Autozone to help with removing the wheel.
    Torspd and BigZ31[OP] like this.
  3. Mar 28, 2025 at 12:24 PM
    BigZ31
    Matthew
    2011 Tacoma 4x4 v6
    Okay sweet thanks for the insight I’ll let yall know how it goes
  4. Mar 28, 2025 at 5:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Turn the steering wheel while holding the horn button down and see if it honks intermittently while rotating the wheel, if it does its definitely the clockspring.
    Torspd, winkel and b_r_o like this.
