horn not working need relay location to check it
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bjack, Apr 19, 2016.
  1. Apr 19, 2016 at 7:14 PM
    Bjack
    Bjack [OP] Member
    99 tacoma 4x4 DLX reg cab
    okay here we go. my factory horn doesn't work so here's what I've done: horn beeps if I straight wire it to battery. No power to single wire at horn. fuse good(reads .03 on voltmeter, same as others) Took off steering wheel/airbag cover and no power to single wire going into harness. I don't know where the relay is so I can't check it. I also heard it may be spiral cable? I am going to put on some claxons but I just wanted to use the steering wheel for the button instead of an aftermarket button but I don't want to spend a great deal of money repairing this thing. by the way my airbag dash light is also on. any help greatly appreciated.
  2. Apr 19, 2016 at 10:57 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The steering wheel air-bag and horn go thru the 'clock-spring', so that is the likely culprit. I think the horn relay is near the inside fuse panel. You should be able to here it click (if working properly) when you try the horn.
  3. Apr 20, 2016 at 9:59 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Could you explain what a "clock spring" is on our trucks? I can't imagine anything like that.
    Where is it located?
    What is it used for?
    What is its Toyota part number?
    Sorry for the questions, but this is the 2nd or 3rd time I've read about a "clock spring" in the last few months and I still don't have a good idea about what/where it is...
  4. Apr 20, 2016 at 10:38 AM
    Bjack
    Bjack [OP] Member
    Thanks for the help
  5. Apr 20, 2016 at 2:25 PM
    tan4x4
    Rick
    Folsom, CA
    The 'clock spring' is a device that allows an electrical connection on a rotating steering shaft. The service manual calls this device a 'spiral cable'.
    Any wired switch on the steering wheel (horn, air bag, cruise control, etc) needs this in order to function properly. To replace it, you need to first remove the steering wheel air-bag module and steering wheel.
    OP, it could be that your 'spiral cable' is defective, or has simply become unplugged.
  6. Apr 21, 2016 at 7:01 PM
    skeezix
    Colorado
    1998 Limited
    >>The 'clock spring' is a device that allows an electrical connection on a rotating steering shaft.<<
    Thank you for the info.
  7. Apr 22, 2016 at 4:21 PM
    Bjack
    Bjack [OP] Member
    okay I have learned a lot in the last couple days. first, I bought an old beat up 99 DLX reg cab 4X4 taco because it was mostly for farm use and it drove and rode great; it just looks like hell but car fax said I am only the 8th owner. My horn was not working and the airbag light was lit on the dash when I bought it so I started testing things and I would recommend in this order. Fuse, direct wire horn to see if it works, horn relay is behind inside cab fuse panel(about 30 minute job to get to it, test it and put back.) All worked so only thing left was clock spring/spiral cable in steering wheel. When I removed the steering wheel (no puller needed) and got to the clock spring spiral cable I found the problem! I took this thing apart and sure enough the wires were broken. New one off Amazon was $18.00 free shipping so it's on the way and I anticipate this will solve both the airbag light and the horn issues since both wires run through it.
  8. Apr 26, 2016 at 10:24 AM
    Sunset Cliffs
    Sunset Cliffs Member
    2001 Toyota Tacoma 2.7 4x4
  9. Apr 26, 2016 at 10:26 AM
    Sunset Cliffs
    Did you get it fixed? thanks
  10. Apr 26, 2016 at 11:12 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    I'm having the same problem with my horn, I've replaced the broken spiral cable, the fuse is good , horn blows when wired direct, NO clicking sound from a relay ? Where is the horn relay located on ' 02 Tacoma Ext.cab ?? Thanks for the help.
  11. Apr 26, 2016 at 11:17 AM
    Sunset Cliffs
    Your spiral cabel was broken, what didn't work
  12. Apr 26, 2016 at 11:23 AM
    Keep on Truckin'
    Jarvis
    Indiana
    Horn still doesn't work ONLY blows when wired direct off battery , I want to check the Relay next cause there is no " clicking" sound when the horn button is pushed .where is the relay located ?? Thanks
  13. Apr 26, 2016 at 11:45 AM
    tan4x4
    Rick
    Folsom, CA
    Don't take offense, but when you re-assembled the SW pad after replacing the spiral cable, did you possibly forget to connect the separate little horn wire? I almost did that once.
  14. Apr 26, 2016 at 11:46 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    $18? Are you sure you ordered the right thing? They are usually multiple hundreds of dollars.
  15. Apr 26, 2016 at 11:58 AM
    Keep on Truckin'
    Jarvis
    Indiana
    No offense taken. I did reconnect the single black horn wire to the terminal on reassembly . Still need to locate the Horn Relay to confirm it's working -No audible click. Thanks
  16. Apr 26, 2016 at 5:07 PM
    Bjack
    Bjack [OP] Member
    Not fixed yet but spiral cable came in yesterday and plan to put on tomorrow and then I will advise
  17. Apr 26, 2016 at 5:15 PM
    Bjack
    Bjack [OP] Member
    My 99 horn relay was on backside of inside fuse panel in top corner. Take plastic knee panel off, then two bolts to loosen where you can turn it around and see the relay. Mine never clicked when I pushed horn because my spiral cable was broken but my relay worked fine when I took it apart and checked it.
  18. Apr 26, 2016 at 5:18 PM
    Keep on Truckin'
    Jarvis
    Indiana
    I'll look near the interior fuse panel & try to locate it. Thanks
  19. Apr 26, 2016 at 5:23 PM
    Bjack
    Bjack [OP] Member
    Addressing the $18 question: I saw prices from $16-$300 for 2 different part numbers that supposedly both fit my 99. I will know if I can install it tomorrow and then I will advise.
  20. Apr 26, 2016 at 7:10 PM
    Speedytech7
    Well I have a spare for 95 that might work, have to check part nums if the one you got doesn't. I thought my spiral was busted but turns out it was the cable that goes to it so I bought a spare spiral for nothing. Oh well, live and learn, should have traced wires better.
