Horn not working properly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nona, Apr 27, 2017.
  1. Apr 27, 2017 at 6:27 AM
    nona
    nona [OP] New Member
    Hi
    Horn on my 2011 Tacoma not working. Changed fuse, still not working.
    Changed relay today, horn worked once. Took relay out, back in and horn beeped as I put relay in.
    Horn works every once in a while now. So still a problem somewhere.
    Spiral Case?
  2. Apr 27, 2017 at 6:44 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    spiral cable is the issue
    remove airbag, bypass horn wire to isolate problem to spiral cable to be sure
    tomwil likes this.
  3. Apr 27, 2017 at 6:47 AM
    nona
    Thank you
    Not something I am comfortable/capable of doing. Off to the mechanic then.
  4. Apr 27, 2017 at 7:48 AM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    Same thing happened to my truck. I tried replacing all the fuses relays etc... etc... Turns out it was the clock spring under the air bag in the steering wheel. I went to the dealer and said hey I am getting a warning light for the Air Bag. Clock spring or spiral cable assembly controls air bag and horn. Wink Wink at the dealer and they replaced it under warranty for the Air bag. The are threads talking about replacing clock spring/spiral cable assembly on this forum. I do not mess with air bags it makes me nervous so I checked my warranty info and got a dealer to cover it.
  5. Apr 27, 2017 at 7:50 AM
    mike92y
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    This was about a $900 fix just for a horn. Horns are required in some states if you have inspection.
  6. Apr 27, 2017 at 7:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    x2 on the clock spring.
  7. Apr 27, 2017 at 7:51 AM
    nona
    Yea, airbag scares me too. Have good mechanic, reasonable prices, will fix it for me.
  8. May 1, 2017 at 9:39 AM
    mitchbuck
    mitchbuck Well-Known Member
    Cape Cod
    12 Taco 2xCab SR5
    Ugh I just had the same thing happen to me! Horn was working intermittently recently then cut out completely. When I hit the panic button the horn still works fine so my guess is its the spiral cable and not the horn fuse/relay (although still going to check). There is no airbag or other light on that would indicate a problem with. Does an authorized dealer need to do this work or a trusted mechanic? How difficult is this to do myself? I've replaced spark plugs, all oils, serpentine belt, etc on my 2012 Taco and was looking up threads here to replace spiral cable. The airbag does scare me a bit though...
  9. May 2, 2017 at 2:11 PM
    mitchbuck
    Cape Cod
    12 Taco 2xCab SR5
    Update: Well I took my truck into my local trusted shop and they confirmed it was the spiral cable/clock spring. They fixed it at a cheaper rate but still cost over $500. I've got 120k miles on her so hopefully its good for at least another 100k. At least this is the first problem I've had on the truck so far!
  10. May 2, 2017 at 2:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Excuse me but doesn't the dealer fix that for free?
  11. May 2, 2017 at 3:56 PM
    mitchbuck
    Cape Cod
    12 Taco 2xCab SR5
    Not that I'm aware of. I had read on here that if it was under warranty still and airbag light was on that they might. But since its 5 years old and 120k miles I'm sure I'm out of luck.
