Horn not working!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jakers83, Apr 10, 2016.
  1. Apr 10, 2016 at 9:30 PM
    Jakers83
    Jakers83 [OP] Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    So went to use my horn the other day and nothing happened so guessing something is wrong lol. So seeing if any of the wise people on here can give me a idea on where to look first. Like where is the fuse for the horn?
    Thanks!
  2. Apr 10, 2016 at 9:43 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Check the 10a fuse under the fuse box on the right side under the hood. Read the fuse box lid to find the correct fuse. Or it might be behind the coin tray, can't remember where it was when I changed mine..
  3. Apr 10, 2016 at 9:44 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Ok I will look in those spots thanks
  4. Apr 10, 2016 at 9:45 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    No problem, good luck bud. I'm almost positive its the fuse.
  5. Apr 10, 2016 at 9:48 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Lol I am hoping. Only thing that seems like it could be and not much work
  6. Apr 10, 2016 at 10:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What year? It could be the spiral cable. The horn relay gets its ground through the spiral cable in the steering wheel.
  7. Apr 10, 2016 at 10:15 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    It's a 2007. That's one thing I am hoping it is not.
  8. Apr 11, 2016 at 10:21 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    So it's not the fuse. Is there a way to check the relay or do I have to just get a new one? How hard is it to remove the air bag?
  9. Apr 11, 2016 at 10:39 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    There is a spiral cable recall notice...check to see if it applies to you. Maybe that would fix it if the horn is ground through the cable.
  10. Apr 11, 2016 at 11:01 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    Oh that would be sweet!!! Thanks for the heads up
  11. Apr 11, 2016 at 3:35 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You can test it by grounding the green wire with a red stripe in the steering wheel if the horn blows it is either the spiral cable or the horn switch in the steering wheel.
    As for the recall Go to the web site and enter your VIN:
    http://www.toyota.com/recall
  12. Apr 11, 2016 at 9:01 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Ok ok it's the spiral cable and my truck is not on that recall. So anyone know how to bypass that or put a switch in?
  13. Apr 12, 2016 at 12:16 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You could bypass the spiral cable and horn button by running a wire from the horn relay coil ( Green Wire with red Stripe ) through a switch to ground.
    Why not do it right and replace the spiral cable?
  14. Apr 12, 2016 at 12:37 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Are you sure you haven't gone deaf?
    Sorry I guess it's one of those "are you sure it's plugged in?" questions...
    ...I'll see myself out. :anonymous:
    Kabloona and Sudsman44 like this.
  15. Apr 12, 2016 at 6:25 AM
    Jakers83
    Jake
    Denver
    2.7 base.
    Because I don't want to mess with the airbag and from what I hear it's not cheap to take it to a shop to have them do it. And it's just a horn
  16. Apr 12, 2016 at 1:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  17. Apr 12, 2016 at 8:08 PM
    Jakers83
    Jake
    Denver
    2.7 base.
    Oh wow that's so freaking easy. Other forms I have read said it was really hard. Now I can replace my steering wheel as well now
  18. Apr 13, 2016 at 1:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well for now it is just a horn, then when other wires in the cable break ( and they will ) you will loose the airbag function and the steering wheel radio controls. all of these go through the spiral cable
  19. Apr 13, 2016 at 4:32 AM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    Same happen to me it was the spiral cable, problem is the part is $240. It is a easy fix just use the above video as a guide.
  20. Apr 13, 2016 at 4:33 AM
    SJC3081
    Wappinger NY
    2011 DCLB 4x4
    Turn your wheel full turn right or left see if horn works. My horn would only blow on full turn.
